Old 11-25-2021, 05:39 PM   #1
Don D
Shortened Automatic tilt steering column
Shortened automatic tilt steering column for those who want a little extra room between the steering wheel & the seat. This moves the steering wheel 2” closer to the dash. It is a direct bolt in with no modifications. ( See Pictures Below ) The column was painted semi gloss black. The following parts are new, shift lever, turn signal lever, tilt lever, turn signal switch & wiring harness with correct wiring harness connector, neutral safety switch, upper & lower rubber seals, indicator lense, indicator pointer, & warning lights knob.
$685.00 plus shipping. Shipping to U.S. Only. No Shipping to Alaska or Hawaii. Payment / Personally Check or Postal Money Order
Don D is offline   Reply With Quote
Old 11-25-2021, 05:46 PM   #2
Don D
Originally Posted by Don D View Post
Shortened automatic tilt steering column for those who want a little extra room between the steering wheel & the seat. This moves the steering wheel 1 1/2” closer to the dash. It is a direct bolt in with no modifications. ( See Pictures Below ) The column was painted semi gloss black. The following parts are new, shift lever, turn signal lever, tilt lever, turn signal switch & wiring harness with correct wiring harness connector, neutral safety switch, upper & lower rubber seals, indicator lense, indicator pointer, & warning lights knob.
$525.00 plus shipping. Shipping to U.S. Only. No Shipping to Alaska or Hawaii. Payment / Personally Check or Postal Money Order
The pictures below have the shortened tilt column & a unrestored truck tilt column to show the difference in the length.
Old 11-25-2021, 07:32 PM   #3
Custom 68
Custom 68's Avatar
Re: Shortened Automatic tilt steering column
I am looking for a shortened but on the engine side if that makes sense. I added rack and pinion so I needed a bit more for that connection. Is there two ways to shorten these? May be a silly question but didn't know where it is shorter if that make sense?
I can't remember if the firewall mount is fixed or slides it's been a long time since I had mine out.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-26-2021, 11:18 AM   #4
Don D
Dave
This column is shortened at the top to give more room in the cab. You do not have a lot of room at the bottom to shorten the column, how much room do you need to connect to your steering?
Don
Old 11-26-2021, 03:52 PM   #5
Custom 68
Custom 68's Avatar
Thanks Don. That's what I assumed. I currently have the steering hooked up and working. It just has a little catch as the joint is close to the limit. I was told thebbest option is to get a shorter column. I would rather stay gm. In fact I currently have a truck tilt. I'm not sure how much is really needed. I figured the 1.5 inches would do it. Looking at my column it do see it is close now to the outer housing. Can a van tilt be shortened any more or is it the same story?
Dave
Dave
Old 11-26-2021, 06:31 PM   #6
Don D
story?
Dave
Dave, the truck tilt, the van tilt & the RV tilt all have the same length column tube. The truck & RV tilt have the same length splined shaft. The van splined shaft is 2 1/2” longer at the bottom of the column. I took some pictures of a truck tilt & a van tilt to show you. If you only need 3/4” of a inch I could get that by having a van splined shaft cut down 3/4” shorter & have it resplined. Another 5/8” to 3/4” could be gained by shortening the bottom of the tube between the bearing & shift arm. Just throwing a couple of options to you to gain some space without creating other problems.
Don
Old 11-29-2021, 08:14 PM   #7
Don D
ttt
Old 12-03-2021, 02:59 AM   #8
kilokoa
ill take the shortened column if its still available. how exactly is it shortened? send me a PM to discuss pay. thanks
kilokoa is offline   Reply With Quote
Old 12-03-2021, 10:21 AM   #9
Don D
PM sent, Thanks
Old 12-04-2021, 08:21 PM   #10
Hosedragger622
How do these columns work with say a 700R4 or 4l60e transmission, they have 4 forward gears and the pic of the shift indicator on yours only shows 3 forward gears ?
Hosedragger622 is offline   Reply With Quote
Old 12-04-2021, 09:02 PM   #11
Don D
They make a 4 speed overdrive indicator lense. Several places sell them, LMC , Brothers & several other parts vendors. Just change the lense out & you have will have adjust the neutral safety switch. It is not a perfect fix since these column’s wasn’t designed for a overdrive transmission but it does work ok. You can’t have any excessive wear & play in your transmission linkage.
Old 12-04-2021, 09:47 PM   #12
Hosedragger622
Sounds good thank you
Old 12-05-2021, 10:25 PM   #13
70cst10_05
70cst10_05's Avatar
Anything still available here ?
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 12-05-2021, 11:34 PM   #14
Don D
The shortened column has been sold. I will have other tilt column’s ready soon.
Old 12-06-2021, 09:24 AM   #15
70cst10_05
70cst10_05's Avatar
Sounds good. If any good "driver" quality ones come up, let me know. I'll keep an eye out on new posts.
Thanks!
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
Kevin
Old 12-06-2021, 10:56 AM   #16
72 paul
Sent a message
72 paul is offline   Reply With Quote
Old 01-13-2022, 10:06 PM   #17
Grandpa's CST
Grandpa's CST's Avatar
Sending PM Don D
..........._____|__\___
..........|_(O)_____(O)]
Grandpa's CST is offline   Reply With Quote
Old 01-13-2022, 10:26 PM   #18
pappy 2
Don,
Interested in purchasing one of your shortened columns. Do you have them on hand? How much to ship to Nebraska? Do you take Pay Pal? Any references?
Send me private mail.
Pappy 2
pappy 2 is offline   Reply With Quote
Old 01-18-2022, 12:32 AM   #19
425HP409
425hp409
425HP409's Avatar
If I sent you my column that came out of a van, would you shorten it and how much would that be?
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-18-2022, 01:37 PM   #20
Don D
$ 475.00 plus parts it may need & you want to change out to make it look like new & shipping fees. Thanks, Don
Old 03-31-2024, 09:57 PM   #21
bertvert72
bertvert72's Avatar
Do you still shorten tilt steering columns for 72 c10's ? And do you already have any done?
Bret
Here's a link to my build
http://67-72chevytrucks.com/vboard/s...d.php?t=577889
bertvert72 is offline   Reply With Quote
Old 04-01-2024, 08:18 PM   #22
Don D
Yes, I still shorten tilt steering columns. I do not have any extra columns built right now. When I get caught up with orders I will build a couple.
Old 04-01-2024, 08:25 PM   #23
bertvert72
bertvert72's Avatar
Please Message me and I'll buy one. How much shipped? Live in Dickson,Tn 37055
Bret
Old 04-02-2024, 07:13 PM   #24
2wd73blazer
I'm interested in a shortened tilt column also.
2wd73blazer is offline   Reply With Quote
Old 04-05-2024, 08:14 PM   #25
Don D
PM sent to you.
