06-09-2021, 09:43 PM | #1 |
Power Window hot lead
I just put in an Electric Life power window kit in a 1972 Chevy half ton. Where should the 12V power lead (s) go to? Some say direct to the battery with a fusible link. Others just put it in the main fuse box - 20 AMP. Where on the fuse box? I do have an accessory fuse box connected but I keep burning out the 3 AMP fuse.
Vancouver Bob |
06-09-2021, 10:23 PM | #2 |
Re: Power Window hot lead
On the 80’s models power windows plug into the fuse box from the factory. So that’s how I would do it.
06-09-2021, 11:05 PM | #3 |
Wish I could. I have other accessories so have an external fuse box to handle them. I think I will just run a heavier gauge line from the battery to an additional fuse box and have it at 20 AMPS just for the power window hot feed.
Vancouver Bob |
06-11-2021, 09:14 AM | #4 |
I went right to battery
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
06-11-2021, 12:14 PM | #5 |
I also ran a primary wire from the battery to an accessory fuse box. 3M double sided taped it to the underside of the dash. Used 20 amps (photo is of a different fuse box for keyed on items).
Vancouver Bob |
