05-12-2021, 06:27 PM | #1 |
Cut 8ft bed Into 6ft Bed
Anyone know of a shop or individual that knows how to or knows someone who can cut down a 8ft bed properly preferably in Michigan or If not Indiana/Ohio? Or have the templates that show.the cut lines around the rear marker lights?
06-04-2021, 08:42 PM | #2 |
Re: Cut 8ft bed Into 6ft Bed
I’m curious about this too, is it just as easy to find a short bed and swap it onto the frame? Can this be done to a 3/4 ton long bed - drop a short bed onto the frame??
Here’s some specs from the Wiki: 115 in (2,921 mm) (short box: ½-ton models) 127 in (3,226 mm) (long box: ½-ton & ¾-ton models) 133 in (3,378 mm) (1-ton models)
1963 C20, small window, long bed 292, 4-speed |
06-05-2021, 07:33 AM | #3 | |
1964 GMC Fleetside SWB 1966 Mustang Coupe |
06-06-2021, 06:25 PM | #4 |
There are tons of threads on this, two main methods if it’s diy. Cut 12 and 8 inch sections out and weld back together or cut and tip the flanges. If your paying someone, buy new bedsides. The labor costs will kill you
