Old 09-05-2005, 01:07 PM   #1
Muddytazz
JMR Offroad
Muddytazz's Avatar
64 stepside
I purchased a 64 1/2ton stepside the other day that I have found out originally had the L6 inline 6 motor. Well the previous owner swapped out the original motor and tranny and and installed a buick V8. Which is no biggie, but here's the kicker. He welded the motor mounts SOLID. What I'm trying to find out is what motor mounts should I be using - factory 283/327 mounts or the buick clam-shell type mounts? I'll have pics later today to post up.
Muddytazz is offline   Reply With Quote
Old 09-05-2005, 11:15 PM   #2
Muddytazz
JMR Offroad
Muddytazz's Avatar
Ok, pics can be viewed here.
http://krazyk5.com/gallery/1964-GMC-Stepside
Old 09-07-2005, 08:31 PM   #3
zenish
you will need to start with buick mounts and build supports for them.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 09-07-2005, 10:09 PM   #4
chevy283
chevy283's Avatar
wow! that's different nice though
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 09-08-2005, 06:49 AM   #5
Sp00ks65
The best I can tell, the bracket looks correct. He just moved the motor from its stock location on the frame. You should have two sets of holes in the frame for different engine configurations from the factory. It appears that he split the difference and instead of drilling new holes, he welded the brackets.
I would be willing to bet the transmission mount is different too, depending on what transmission is currently in the truck. If he used the stock tranny it may be in the stock location.
Sp00ks65 is offline   Reply With Quote
