Old 05-19-2022, 01:06 AM   #1
Yeller
62 front shocks
The front shocks on my 62 c10 need replaced. I have a couple questions for the board.
1. How do you tell if the truck has been lowered from a stock 62? I think it may have been lowered just in the front and possibly by adjusting the torsion bars. Where can I measure from or get the stock layout to check.
2. If the truck has been lowered will a stock front shock still work or do I need to measure from a specific point to determine shock replacement length.
3. Best shock for this application? I can afford decent quality 125-150$ range per.
I think I would be better off if I were to swap crossmember to a later model but right now I’m living out of an rv til the house and shop get rebuilt so I don’t want to tear it down too much til then and I get to replacing some tools. The driveway is uphill so the trucks stance isn’t quite as apparent here as when on flat ground.
Yeller is offline   Reply With Quote
Old 05-19-2022, 01:18 AM   #2
Yeller
Re: 62 front shocks
Just adding a picture of the current L front shock as viewed from the rear.
Old 05-19-2022, 10:27 AM   #3
SkinnyG
SkinnyG's Avatar
Re: 62 front shocks
You will be fine with a stock shock.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-19-2022, 11:26 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 62 front shocks
Get us a picture of the torsion bar adjustment bolt.
If it's been lowered, depending on how far, they'll be sticking down a ways. Otherwise, they should be tucked up within the crossmember.
Look at page 2 of this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=472091.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
