07-13-2021, 05:29 PM | #1 |
454+headers+A/C brackets?
I'm going to put headers on my '77 454 that is currently at the engine builder shop. It will get a Edelbrock intake too. It just dawned on me, can I keep my existing OEM A/C compressor and brackets or is there an aftermarket set I need to get? The truck is a '77 C10 step w/factory 454. The A/C works great, I'd like to keep it. Anyone gone through this with a BBC?
07-13-2021, 06:01 PM | #2 |
Re: 454+headers+A/C brackets?
Not sure if your OE AC brackets will work but if it's helpful, I am running a 454 (Gen VI 7.4L)
Headers = Sanderson ceramic 3/4 length BBC headers for 67-87 Truck, patented leak-free flange design. I'm very satisfied with these headers. (https://www.sandersonheaders.com/san...category_id=27) AC brackets = Because I am running an aftermarket AC system from Old Air, I am using their AC/Alternator brackets. Depending if it's long or short water pump (https://www.oldairproducts.com/categ...parts/brackets)
66 GMC Suburban Custom 66 Chevy K10 Suburban |
07-13-2021, 06:21 PM | #3 |
I have used all thread couplers, or 1/2 gas pipe for nipples to space out the bracket for power steering. Then ran the factory bolt back through the spacer.
07-13-2021, 07:14 PM | #4 |
My question would be---are headers really needed? I get a pretty good flow out of my cast irons into a single 3'' semi built 454 nothing radical, 30 over flat tops 9-1 compression 268 cam. engine screams
07-13-2021, 10:46 PM | #5 |
No, but I would look for the best flowing manifolds you can get.
Look up castheads on YouTube. He builds nascar Saturday night special engines. From what I see he specializes in small blocks, and mostly chevy. Either way you can pick up a few ideas to increase flow. Below 3000rpm probably not much change, but after with that cam you will feel a difference. |
