Old 07-17-2021, 06:41 PM   #1
nobolt
nobolt's Avatar
lifted K20 highway tire options?
Hi guys, I just bought a lifted 1980 K20 but before I take it off road I need to do some trailering with it. maybe 10+ trips of 600 miles each. so... I was looking for some highway tires that wouldn't drone me crazy like the current 35x12.5x16.5 Super Swampers. I realize I will probably need wheels as well. Any suggestions?
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 07-17-2021, 06:58 PM   #2
Getter-Done
Getter-Done's Avatar
Re: lifted K20 highway tire options?
First off , Nice Truck.
I am in the same situation with my 84.
I have 16.5 Super Swampers also.
Your best bet is buy a set for street use.
Get away from the 16.5 tires and rims.
Just use those for offroad till you wear them out .
16.5 stuff is hard to find and Pricey if you do.
I tried to sell them at a swap meet one time
I could not even give them away
84 Chevy K-20
Old 07-17-2021, 08:17 PM   #3
Nick_R_23
Nick_R_23's Avatar
You can still buy 16.5” highway tires, but the Super Swamper Vortrac LT is going to be about the only decent option:
https://www.intercotire.com/tire/141
TrXuS MT would be a more mud terrain style tire, but also available in 16.5:
https://www.intercotire.com/tire/102
Old 07-17-2021, 09:51 PM   #4
84 400
Sb 400 club
84 400's Avatar
If you want to keep your currebt rims get military supruls tires from a hummvee. They are 37/12.5r16.5 and heavy load range. The goodyear MT Oz radials wear like iron and can haul a load. The BFG is good too. Avoid the MTR as they had sidewall issues. Here is what i ran but again these are 16.5 and you can pick them up for under 150 a tire with 90% tread..
Obviously you don’t need the beadlocks and could resell the wheels and get military tires even cheaper…
Otherwise get aome hummer H2 17 inch wheels with tires or 17 inch rims in general since the tire selection is good..
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 07-17-2021, 10:13 PM   #5
84 400
Sb 400 club
84 400's Avatar
Wait what gear ratio, engine and trans and how heavy a trailer you pulling? You may eant to run stoxk sizr for towing depending on ehat your pulling
1985 C10 LWB Sold
Old 07-17-2021, 10:28 PM   #6
nobolt
nobolt's Avatar
a lot to think about thank you. i always liked the white factory look, i wonder if i can find something like that in a 17".... back to google i guess
Dave
Old 07-17-2021, 11:57 PM   #7
Nick_R_23
Nick_R_23's Avatar
84 400 also has a good point. If you can find takeoff H2 wheels, they’re wide bell, 17” diameter, and fit the 3/4 ton trucks well. Stock H2 tires are 35”, so if you get a complete setup, you can swap back and forth as you wish with your current wheels.
I just put H2’s on my 3/4 ton, super easy. Although, I won’t be keeping the 35’s!
http://67-72chevytrucks.com/vboard/s...3&postcount=10
Old 07-19-2021, 08:22 AM   #8
MJN
MJN's Avatar
I'm running the Goodyear Wrangler military tires on mine- actually they've been on the truck since 2009. They're quiet on the road and wear really good too.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-20-2021, 07:04 AM   #9
nobolt
nobolt's Avatar
beautiful truck! I'm leaning to the military tires on some stock rims. I'll have to see how i like the Interco tires too. I plan on a lot of miles before winter so I should have a good idea of what I'm dealing with shortly. Thanks guys
Dave
Old 07-20-2021, 10:10 AM   #10
MJN
MJN's Avatar
I haven't trailered with mine- I don't have a receiver on mine. I do use mine to haul lumber, retaining wall blocks, bags of concrete mix, etc. and usually that stuff gets heavy pretty quick- the closest Menards or Lowes is 35 miles away and it will run 65/70 mph no problem. Haven't had an issue with these tires and I keep them around 30 to 35psi.
'17 GMC Yukon XL
VCCA member #58596
Old 07-20-2021, 11:33 AM   #11
kwmech
I'm running the KOYO A/T open country on my Suburban ---smooth, quiet.
