11-15-2014, 10:45 AM | #51 |
Re: Urgent, need opinions on my new crate engine
I think you're going in the wrong direction with your motor choice 1972Blue.
You were worried about your choice of the 290 hp motor and now you're jumping deeper into the fire with even more motor. You've got a big tall tire heavy truck that needs all the torque you can find. Buying more hp moves the hp/torque curve way up the ladder. Right out of your desired driving area. It'll be a dog until it hits 3000 rpm. You need a stock motor with some upgrades. Like this one. http://www.summitracing.com/int/sear...g&autoview=SKU Add a high flow performer intake, a small 600 cfm carb, a set of small tube (1 5/8") headers and you'll be far happier. You'll set the tune on your motor and only need to look at it to check the oil. The high horse motor will need constant attention. You'll be continuously tweaking the carb, checking the timing etc. Forget the bling bling high horse motors, go stock. Unless you enjoy tinkering all the time! |
11-15-2014, 11:10 AM | #52 |
So I'll be happier with a 195 hp 350 tq engine over a 330 hp 380 tq engine?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
11-15-2014, 11:21 AM | #53 |
Maybe!!
Do you do your own wrenching or get a mechanic to do it? Do you do your own timing or carb adjustments? Do you normally drive above 3000 rpm? |
11-15-2014, 11:23 AM | #54 |
Thats what controls hot/cold on your heater. You should have one in the heater return hose
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
11-15-2014, 11:27 AM | #55 | |
As for my driving, I drive pretty aggressive. Not drag racing from light to light, but pretty aggressive. Or I'll just cruise normally and I don't care about power till I floor it. Lol I never haul or tow anything.
11-15-2014, 11:31 AM | #56 | |
Stock is NEVER a good answer to anything.....LOL
11-15-2014, 11:39 AM | #57 | |
That's what my mechanic said. I asked him about just buying the cheap engine and he said why go through all this $$$ and trouble just to get a stock engine. Keep in mind, he doesn't make any more money on the install regardless of whether I buy the vortec engine or the base engine.
11-15-2014, 11:47 AM | #58 |
The 290hp engine is just a mismatched mess!
At 2500 rpm, the 290hp engine has about 280lbs of torque, and the 330hp engine has about 350lbs. 70 lbs is a LOT, and you WILL notice it!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
11-15-2014, 11:52 AM | #59 | |
That's what I figured.
11-15-2014, 04:30 PM | #60 | |
The front of the engine is not affected and takes a regular balancer. Production Vortec 350's (L31's) take a shorter balancer due to crank sensor, those are the ones with plastic timing covers and reluctor wheel between the lower timing gear and the balancer. |
11-15-2014, 04:36 PM | #61 | |
11-15-2014, 05:33 PM | #62 | |
You don't need a special balancer, but I would get a new one. I think you already got this one, right? Perfect. http://www.summitracing.com/parts/su.../applications/ It will fit. Just make sure you use the correct indicator http://www.summitracing.com/parts/su...make/chevrolet You do need a special flywheel AND flywheel bolts to fit that engine. It's NOT the same as a 383 or 400, it's the same flywheel that chevy has used since they started 1pc rear main seals starting in 86. Again, there is a 153 and 168 tooth I'd get whatever one matches the starter you already got. The difference is the 153 will crank your engine faster, but not harder. The 168 will crank your engine harder, but slower. This one will do you for a 168 tooth slow cranker http://www.summitracing.com/parts/pi...make/chevrolet This one will do you for a 153 tooth fast cranker http://www.summitracing.com/parts/pi...make/chevrolet Flexplate bolts http://www.summitracing.com/parts/nal-14088764 You know you need a new Vortec style intake, right? You have an Edelbrock square bore AFB style carb, right? The Best, $250.00 http://www.summitracing.com/parts/ed...make/chevrolet Cheaper http://www.ebay.com/itm/SBC-SMALL-BL...26b88c&vxp=mtr Intake gaskets, get these they fit, do not split, last a long time. http://www.summitracing.com/parts/na.../applications/ And, of course, special intake manifold bolts, sold individually, you will need 8. http://www.summitracing.com/parts/na...0027/overview/ |
11-15-2014, 05:48 PM | #63 |
Nope he just likes them really really fat..................
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
11-15-2014, 05:50 PM | #64 |
11-16-2014, 01:19 AM | #65 |
Vintage 4x4s
Except when lowend torque has been compromised for more high end horsepower.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
11-16-2014, 02:34 PM | #66 |
I don't have any kind of heater temp valve. The lines are just straight from intake to core, and from core to waterpump.
11-16-2014, 02:38 PM | #67 |
Thanks guys for all your input!
I think I'm going to send a lot of my parts back along with the 290 hp engine since they are paying for all the return shipping. I'm going to just get this complete package. It's more of a turn key almost deal. My phone won't post link right now Arggg Gm part # 19210008
11-16-2014, 03:23 PM | #68 |
Vintage 4x4s
That is the way these trucks are. Heat is modulated by a flapper that diverts air either through or around the heater core (in the fiberglass box mounted to firewall.) Not sure if burbs are different or why Lattimer has a different setup.
11-16-2014, 05:50 PM | #69 | |
IMPORTANT That engine needs a thermostat by-pass hose. PLEASE don't let ANYONE talk you into drilling holes in the thermostat, this makes your engine take longer to warm up. Bypass hose will NOT make the engine take longer to warm up as it goes back to the water pump (not cooled by the radiator) or the cold side of the radiator ready to be sucked into the water pump. IF you DON'T have a/c, and you DON'T install a heater valve and you DO keep coolant circulating from the top of the intake into either the water pump or the cold side of the radiator, then the heater circuit will function as a by-pass hose. CAUTION if your heater starts leaking, you by-pass it and forget about it then you could damage your engine. I would not do that with my forgetfulness. IF YOU DON'T have any thermostat by-pass, eventually air/steam pockets will form before the thermostat opens and the thermostat will not see hot water to make it open, the engine will get hotter and hotter and you will eventually either blow hoses, heater core, radiator, and worse yet crack the heads. Here is an example of a vortec style engine with a by-pass hose, but it's a Ramjet 350 and that manifold has a fitting on the front for the heater supply. For NON-a/c, heater supply you need what you probably already have a "restricted" 5/8" fitting. http://www.napaonline.com/Catalog/Ca...515_0421632233 Shown is a short water pump, the fitting on the top for t-stat bypass and the fitting on the side for heater return. The heater return can also go to the nipple you will sometimes see on the cold (passenger) side of the radiator. Another problem: For your temperature warning system, gauge or idiot light, your sensor or sender may be too large (1/2"NPT) to screw into the smaller hole on the Vortec head (3/8"NPT). However, the intake on your new engine might have the right passages to accommodate everything. The upper one on the passenger side for your heater fitting, the one on the upper driver's side for your temperature warning sender or sensor, and the one in the front for your thermostat by-pass hose. The bypass hose can be 5/8", you will have to remove the plug atop the water pump and adapt down to the proper size fitting for the hose you choose, or drill a hole in the plug and pipe tap it to the size you need. https://www.google.com/search?q=3/8%...IQsAQ&dpr=0.95 https://www.google.com/search?q=3/8%...+5%2F8%22+hose https://www.google.com/search?q=3/8%...+5%2F8%22+hose https://www.google.com/search?q=3/8%...+5%2F8%22+hose Lots of these can be found at Home Depot, Help sections at auto parts stores, or online, but I expect your mechanic will figure it out. If he (your mechanic) balks and wants to drill your t-stat, I'd round up the fittings myself and go to the parts store and get a pre-formed section of heater hose and cut it to fit. He's going to be in a hurry, and really don't get paid to run around and hunt parts. IF the hole in the driver's side top of the intake is not 1/2"NPT but instead 3/8"NPT (hard to be sure just looking at the picture) you can use a different sensor and either put it there or leave it in the head. I think leaving it in the head looks better, but a better sample of pre-thermostat temperature on the intake, but might poke into the radiator hose. Splitting hairs LOL. For 3/8"NPT Idiot light use Duralast TU81. For 3/8"NPT Gauge sender use Duralast TU66. You may have to install a female spade connector but it will probably shove on there. When your engine arrives, look over the intake/heads, check the water pump plug, sensor/sender on your old engine, and get your parts lined up coming so the installation can proceed un-hindered. Of course have it delivered directly to the shop installing it. |
11-16-2014, 06:18 PM | #70 | |
I notice your 67 has a/c, but you don't show it on your newer trucks. I'd be interested to know just when they started putting it on. 72 is C10, 68 is C20. Last edited by mechanicalman; 11-16-2014 at 06:20 PM. Reason: add-on |
11-16-2014, 06:35 PM | #71 | |
My truck was non ac and had a cable operated valve in the heater hose line. I tore all of that out and put in aftermarket air, but it uses basically the same water valve.
11-16-2014, 06:57 PM | #72 |
I bought the 195 HP 350 crate engine along with the summit TH350 rebuilt transmission a year or so ago. I put them in a 1974 GMC stepside 1/2 ton long bed. I am very happy with both to date. It has headers with a quadrajet carb and an Edelbrock 2701 Performer Intake Manifold. I have to be easy on the gas peddle, It wants to jump down the road.
11-16-2014, 07:19 PM | #73 |
Fast. Cheap. Reliable. Pick two.
71 K20 64 GMC mud truck |
11-16-2014, 08:01 PM | #74 |
11-16-2014, 11:06 PM | #75 |
Good choice on the engine, while it is more expensive now I think it will be a better piece for you in the long run. The 1 piece rear main and vortec heads are worth it.
