05-12-2022, 11:31 AM | #1 |
4L60e mated to a 6.0?
I received an engine out of a 2002 LS 6.0 LQ4 which was mated to a 4L60e, but now I am having trouble finding a wiring diagram for such. Its kind of odd as it has a DBW system and different components than say the more popular DBW of the 2003-05 models. Any ideas where I can locate a wiring diagram? for such?
Pic for attention.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
06-07-2022, 06:54 AM | #2 |
low n' slo
Re: 4L60e mated to a 6.0?
are u looking for a stock diagram or rewired one for a swap (like the one you posted)?
my 2002 5.3 was also a weird dbw and it was flex fuel. but it was still very similar to a dbc. the only difference I found was a weird connector on the trans plugs branch (flex fuel connector) and you will have a connector up front where the passenger side injector wire harness starts...and that one is your dbw plug to the throttle body. is the 6.0 more optioned?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-24-2022, 09:27 AM | #3 |
Junior Member
I have found a wealth of information on LS swaps at LT1swap.com. You may find something there - if not, there is still tons of very good info on how to complete a swap.
