Old 05-20-2016, 07:25 AM   #1
CUSTOM/10
CUSTOM/10's Avatar
Bench seat foam "help"
Hey Guys !
I want to hear your experiences with replacement Bench Seat Foams ! I know of 2 manufactures: American Cushion & PUI. and I'm sure there are imports also.
I have a 71-72 Full Foam Seat and a new cover from Truck Seats. My upholsterer says I need new cushions or to have him build new foams. Because he's so busy he would prefer I buy the foams pre-formed. But I'm reading some are too dense and people are having issues with head room and leg clearance between the seat and steering wheel.
Help me make a decision on what mfg. of foams to use, tell me the good, bad & ugly !!!
Thanks in advance !!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 05-20-2016, 07:31 AM   #2
boogieman1
boogieman1's Avatar
Re: Bench seat foam "help"
I bought the set from LMC and are pretty happy with them. They seem like good foams and fit well but they did push me a couple of inches closer to the roof.
'72 chevy C20 Cheyenne Super
boogieman1 is offline   Reply With Quote
Old 05-20-2016, 07:43 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
Thanks Boogieman ! Do you know who's cushions they sell ?
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-20-2016, 10:45 AM   #4
CUSTOM/10
CUSTOM/10's Avatar
Anyone else ???
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-20-2016, 12:21 PM   #5
heathbirkendahl
Originally Posted by CUSTOM/10 View Post
Anyone else ???
Don't buy the expensive stuff. It's to dense!!! I had to cut mine down.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 05-20-2016, 12:26 PM   #6
CUSTOM/10
CUSTOM/10's Avatar
Thanks !!! heathbirkendahl, Do you know who made the foams you had to cut down ?
This is the kind of info I'm looking for, do you know if it was PUI or American Chusion ?
Oh and did you have the full foam seat frame or the standard seat frame?
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-20-2016, 04:52 PM   #7
CUSTOM/10
CUSTOM/10's Avatar
Anyone know the manufacture of seat foams you had good luck with ?
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-20-2016, 09:19 PM   #8
Grumpy old man
Grumpy old man's Avatar
Post a picture of your seat foams , it just sounds like your upholster is lazy it usually much easier ,cheaper and a better fit to repair what you have rather than replace it with over priced aftermarket foam that doesn't fit .
Old 05-21-2016, 06:41 AM   #9
CUSTOM/10
CUSTOM/10's Avatar
Hey Grumpy!
I have no pics at this time, but Repairing the seat is still an option, he will do what ever I want from repair to replace or custom build new foams. I'm looking for the option that will give me a nice useable / comfortable seat without going crazy with the $$$. I can get PUI foams for $185 from Jegs. But would like to hear feed back about them. He is a PUI dealer but has never used the 69-72 bench cushions from them, he's going to call them Monday and get the low down. He recently did a seat for a customer that brought his own foams and had the issues of being too stiff & tall. ( he'd didn't know the brand ) he had to cut them down. I'm / we are doing the research before jumping into it.
More feed back Guys !!!
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-21-2016, 06:48 AM   #10
John H.
John H.'s Avatar
Hey Gary,
I have a nice set of original foam in good shape from 72. I could post pics tomorrow?
John H. is offline   Reply With Quote
Old 05-21-2016, 06:53 AM   #11
CUSTOM/10
CUSTOM/10's Avatar
Hey John !
Are they full foam cushions ?
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-21-2016, 06:55 AM   #12
John H.
John H.'s Avatar
Yes. I will post pics later today. On a plane from Newark to seattle
Old 05-21-2016, 07:02 AM   #13
CUSTOM/10
CUSTOM/10's Avatar
Sounds good John.
STILL LOOKING FOR FEED BACK ON NEW FOAMS !
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-21-2016, 09:43 AM   #14
Grumpy old man
I've been building interiors for a very long time ,replacement foams are not only expensive but junk in my opinion and I've rebuilt thousands of seats over the years , Believe me when I tell you your butt will not tell the difference between an original good condition foam and one that has been correctly repaired . Foam is cheap to buy a piece large enough to repair just about any damage and many guys fix their own and install their own replacement covers with great results .we used to charge a $100.00 to install a customer supplied seat cover including basic foam repair and those jobs always went to the low guy in the shop and took less than an hour . An electric carving knife for $10.00 cuts and shapes foam just as good as my $500.00 Bosch foam saw. And contact cement can be purchased at any home store and can be brushed on we used to install carpets ,jute padding and vinyl tops for many years brushing the glue on . I suggest you fix it yourself as a weekend project and you'll find many uses for the left over contact cement .
Old 05-21-2016, 09:48 AM   #15
CUSTOM/10
CUSTOM/10's Avatar
To do what you just described he would charge $165, and that might be the way I go !
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-21-2016, 11:21 AM   #16
Davidf
I need to do the same and plan on doing as GOM suggests. Suggestions on foam density that most closely matches original foam would be helpful from anyone in the know..
Davidf is offline   Reply With Quote
Old 05-21-2016, 01:43 PM   #17
midniteblues
midniteblues's Avatar
i really dont understand "buying" brand new foam. it cost way too much for what it is.
junk yards are filled with vans,busses,motorhomes and trucks
most have perfect bench seats in them.
in the back of full size window vans they have rows of removable seats there is great foam in these and sometimes the covers are useable just for the material...its good stuff
measureing is really important. and the foam is so easy to shape the way you need it. you can add layers of differnt density foam to achieve maximum comfyness
now i understand those who do concourse restorations and want everything perfect.
but those who are capable and willing and on a budget can get it done for way less.
right grumpy
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-21-2016, 02:09 PM   #18
John H.
John H.'s Avatar
Here is the lower. The back is in the same or better condition.
Old 05-21-2016, 02:10 PM   #19
John H.
John H.'s Avatar
Old 05-21-2016, 02:11 PM   #20
John H.
John H.'s Avatar
Old 05-21-2016, 02:11 PM   #21
John H.
John H.'s Avatar
Old 05-21-2016, 02:12 PM   #22
John H.
John H.'s Avatar
Old 05-21-2016, 02:13 PM   #23
John H.
John H.'s Avatar
Old 05-21-2016, 02:14 PM   #24
John H.
John H.'s Avatar
Old 05-21-2016, 02:16 PM   #25
John H.
John H.'s Avatar
