Old 07-03-2002, 11:12 PM   #1
TonyM
TonyM's Avatar
any tips on oil pan change?
Never done this before, but seeing as how my engine will be out anyway, I was wondering if anybody has any helpful tips on replacing the oil pan. Is it as straightforward as it seems? My old one has a hole in it Thanks.
68GMC in family since new
Victoria, B.C.
Canada
TonyM is offline   Reply With Quote
Old 07-03-2002, 11:43 PM   #2
dion
72 Cheyenne
dion's Avatar
Make sure you get good seals, they like to leak. Good sealant and gaskets and you shouldn't have a problem
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-04-2002, 09:22 AM   #3
hanssolo
hanssolo's Avatar
Like dion says, use plenty of sealant on both sides of gasket. Two diff. sizes on pans up front depending on year of pan. They usually give both sizes in gasket kit. Make sure you use the right one.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 07-04-2002, 09:49 AM   #4
racedvl
racedvl's Avatar
I would use Fel-Pro's one peice oil pan gasket. I'm using one, and I LOVE It!!! Does not leak a drop!! hehe.
racedvl is offline   Reply With Quote
Old 07-04-2002, 10:55 AM   #5
junkyardjohn
junkyardjohn's Avatar
Thumbs up
I SECOND THE ONE PIECE OIL PAN GASKET. THEY ARE GREAT.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-04-2002, 12:11 PM   #6
TonyM
TonyM's Avatar
Thanks a lot you guys! I'll go with the one piece Fel-Pro.
Victoria, B.C.
Canada
Old 07-04-2002, 12:22 PM   #7
my new 72
faster, faster, faster
my new 72's Avatar
Just make sure to follow the directions for applying the sealant that come with the gasket. It is very important that you only use sealant where it says to, if you don't you will get a leak. And be acurate on the torqueing of the bolts too. Follow all the steps outlined in the directions, and you will never have a leak.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 07-04-2002, 12:34 PM   #8
greasemonkey
greasemonkey's Avatar
Drain the oil first, hehe.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 07-04-2002, 12:58 PM   #9
jhwkns
Registered Cruiser
jhwkns's Avatar
It's not uncommon for the flange on the pan to become distorted from being previously overtorqued. I always check for this. If it is streched in around the bolt holes you can flatten it out with a small hammer. Go easy with the gasket sealer or all of the excess will end up on your oil pump pickup screen. Even the best gaskets shrink a little, so check the pan bolts after a couple weeks to make sure they're still snug. Hope this helps.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-05-2002, 06:56 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
i put oilpan studs in place of bolts...
they kick a$$...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-05-2002, 08:49 PM   #11
68 Stepside
huh?
68 Stepside's Avatar
I have also used the one piece felpro gasket. I love it, and if you ever have to take your pan off, you can reuse it! It's a very nice setup, comes with new bolts and everything.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-05-2002, 10:32 PM   #12
racedvl
racedvl's Avatar
Gee, TJ, I wounder where you got your pan gasket from??
Old 07-06-2002, 05:28 PM   #13
jlmtrout
I agree, one piece rubber gasket is the only way to go. Also, make sure you get the right year oil pan. Not all sbc oilpans have the same front and rear seal clearances. Good luck and keep on truckin'!
jlmtrout is offline   Reply With Quote
