11-05-2012, 05:37 PM | #1 |
Wheel size 17'' to 16"
I have a 2005 Chevy silverado crew cab 2wd that has the stock 17 in steel wheels. It has disc brake front and drum rears. Can i put 16 in rims stock without issues. It will give me a better selection and cheaper cost of new tires if i can do this. Any info on this?
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
11-05-2012, 06:25 PM | #2 |
Re: Wheel size 17'' to 16"
No. In 05, they started installing 13" disc brakes. 17" wheels are the minimum size wheel that will fit on 05-up trucks.
11-08-2012, 03:51 PM | #3 |
I put 16 inch wheels on my pickup but I had to grind down the front calipers for clearance. Probably not the right way but worked. And 16 inch tires are cheaper than 17s.
Posted via Mobile Device |
11-08-2012, 05:54 PM | #4 |
Do you have a pic of where you ground the calipers also is there any issues with speedo calibration with the 16" tires?
11-08-2012, 11:00 PM | #5 |
DO NOT modify brake components.....Common sense guys.
11-08-2012, 11:28 PM | #6 |
laying low
Right.
11-11-2012, 08:27 PM | #7 |
Sorry I dont have any pictures. I just ground on top of the caliper where it rubbed the wheel. I ground just enough so it clears I didn't have to take a whole lot off. The caliper is real thick cast I dont believe I ground enough off to damage anything. As for the speedometer it just depends what size tire you run.
11-12-2012, 12:36 AM | #8 |
So would the 05 wheel in 17" be the same as the 08 17" as far as offset?
I have a buddy with an 05 and he wants my old winter tires. P245/70r17. Should they fit?
"I feel the need for speed!"... as soon as I am done with my nap. |
