Old 11-22-2021, 09:44 PM   #26
68mg
68mg's Avatar
Re: A grandpa’s camper truck resurrection
Great project, just subscribed. I picked up a 69 C20 last year and working through some of the same things, but going much slower. I finally cleaned all the leaves and crud under the cowl and back below the vent doors, also replaced the cab mounts. Yours is looking great already and it looks like the type of truck you might even find the build sheet. I got lucky and mine was still behind the seat, purchased from Appleway Chevy in Spokane.
68mg is offline   Reply With Quote
Old 11-23-2021, 01:24 AM   #27
chev-obsession
chev-obsession's Avatar
That’s cool man, these trucks are a lot of fun and relatively easy to work on. That’s funny you say that, my tailgate has an Appleway Chevrolet sticker on it
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-24-2021, 12:27 AM   #28
yuccales
yuccales's Avatar
Looking good under that hood! You're not wasting any time that's for sure!
yuccales is offline   Reply With Quote
Old 11-25-2021, 09:12 AM   #29
Truck is looking good. Looking forward to seeing the rest of you work.
Old 11-25-2021, 11:20 AM   #30
chev-obsession
Thanks guys! I’ll keep you guys updated.
I got a LOAD of parts to start working on the front end and new hoses, fluids, tune up type stuff yesterday and plan to hit it hard this weekend. Also my friend who rebuilds carburetors was able to get mine done. It looks great and he really did a great job rebuilding it.
I Need to drain the old gas out of the main tank and get it cleaned out so it can start drying. Then I’ll probably start on the front end stuff, or maybe the engine . Idk we will see where it takes me.
Have a great Thanksgiving everyone!
1965 c/10 swb
1969 c/10 lwb
Old 11-25-2021, 12:15 PM   #31
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Subscribed to watch. Nice find!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-25-2021, 12:23 PM   #32
67RS/SSx2
Great find. Loved the camper. When I was a teenager we had a 68 C10 with rear coil springs and a 9 ft overhead camper. Had to drive that mammoth to high school many times. It lumbered in turns so you had to take them a little slower than normal.
Your progress looks great. Happy for you. Good luck with the restoration!
1972 C20 402/TH400/3.54 Highlander
1969 Camaro RS with SS trim, 1967 Camaro RS/SS (sold)
1983 GMC Sierra Classic 2500 crew cab (sold)
1972 Chevy C10 Cheyenne Super (sold)
1984 Chevy Silverado C20 crew cab (bought new by my uncle, in the family until I sold it)
67RS/SSx2 is offline   Reply With Quote
Old 11-25-2021, 01:18 PM   #33
yuccales
yuccales's Avatar
With all the new parts you're throwing at it, that truck has a lot to be thankful for! Have a great day.
Old 12-01-2021, 02:58 AM   #34
chev-obsession
I didn’t get nearly the amount of work done this weekend as I would have liked to. I did a lot of “inspecting” since it was the first time I really got to look at things with much less grease and actually being able to craw under it. I did see that my truck was sold from the local dealer in Pasco, so it’s stayed in the area it’s whole life. So the pictures are less than what anyone would expect. I did get the seat, gas tank and front end removed. Gas tank looks like it has a lot of solidified crap in the bottom. I have 2 more spare tanks that I’m going to take a look at and see if one is better.
I did notice that the truck never had a front sway bar… this thing must of handled like CRAP especially with a heavy camper on the back! I can only imagine this thing bouncing all over the place. So now I’m on the hunt for a sway bar, preferably a 1.25”. But any bar would be better than none.
I did notice these goofy magnets and UHMW plastic contraption on the steel fuel line. I’m assuming that was some kind of rig up to avoid heat soak/vapor lock. It was removed
I also noticed the rear axle bearings have a noticeable amount of play on the drivers side, not so much on passenger. Driver side rear drum had an abnormal wear spot (deep groove) on half the drum, so new drums on the rear. Panhard bar and trailing arms need new bushings too.
Front end came apart without too much fuss, I will need to get the old ball joints removed and would like to pressure wash those again to get them squeaky clean. I don’t think i will repaint anything, just leave it in it’s rusty/patina state.
The front shocks weren’t doing a damn thing, they were difficult to compress and didn’t return at all. I think they need some Viagra
The rear shocks I think we’re doing a ton of work, super stiff and when I removed them the bed dropped a couple inches.
Lastly, I noticed the intake was over tightened and the gasket was squished out. So now that I need to pull the intake to replace the gasket, I think I want to pull the heads off and put better non smog/ thin casting heads on. I don’t want to have to drain the anti freeze, pull the intake and distributor again if I don’t have to. Also noticed the heat crossover and manifolds have gotten hot… not sure what that is all about. Anyway enough boring stuff. I have another parts list going and hoping to get the front end back together shortly.
Old 12-01-2021, 02:59 AM   #35
chev-obsession
Lol yeah seriously, it’s been slightly neglected!
Old 12-01-2021, 03:01 AM   #36
chev-obsession
A couple front end pics. You can see where the manifold was over heated. Not sure what that cause is, I’m thinking carbon buildup on the cross over, or the flapper before the manifold isn’t working correctly.
Old 12-01-2021, 11:53 AM   #37
68mg
68mg's Avatar
Great progress, looks like a pretty original and unmolested truck and it sounds like it has the original 350 in it. Also pretty cool that you found the build sheet and it's been a local Tri-Cities truck. Interesting that they didn't add the swaybar since your SPID shows they added both the HD rear springs and also the aux. spring. They could have added a C10 Custom Camper badge with the swaybar and the right tires.
Old 12-01-2021, 06:10 PM   #38
BigBird05
Those heat riser valves always go bad and coke all of the exhaust up thru the intake. Check it out and i'll bet you it will be bad.
BigBird05 is offline   Reply With Quote
Old 12-01-2021, 06:43 PM   #39
zellway
zellway's Avatar
This looks like a great project. I wish I still had my fathers old camper from my 67. Excited to fallow along on this build
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 12-01-2021, 07:13 PM   #40
Louisvillekytruck
Nice find
Louisvillekytruck is offline   Reply With Quote
Old 12-03-2021, 01:26 AM   #41
chev-obsession
Im not sure if the engine is 100% original, it was rebuilt at Tacoma Auto Machine and has the tag on the front of the block. Yeah I thought it was pretty cool that it stayed local all these years! I agree on the custom camper... my thought s exactly, or why not upgrade to a c20?
I will definitely do that and report back... at some point
1965 c/10 swb
1969 c/10 lwb
Old 12-12-2021, 03:54 AM   #42
chev-obsession
I haven’t had a ton of progress the last week or two. I was able to get the lower control arms off, steam cleaned all of the old grease off LCA’s and steam cleaned the inside of the gas tank. Got the new lower ball joints pressed in, and upper ball joints installed. Pulled the remaining brake lines from the master down to the drums and rear line. Also scrubbed the dirt and grime from inside the cab before I install the tank. I didn’t take a before picture, it wasn’t horrible but it wasn’t real clean either.
While I was in scrubbing the cab I had pulled up the vinyl floor mat and found a little pouch of keys. Turns out there was a key for the ignition!
When I was first going through the cab of the truck and camper, I found enough tools and spare parts to dang near rebuild the engine on the side of the road then I’m thinking, if this guy was this well prepared I’m sure that he had a spare key hidden somewhere. Turns out it was tucked up under the floor mat a ways
I’m really glad to find it because I was dreading having to drill out the ignition cylinder.
I have the spindles soaking in vinegar to remove the rust, I’m not sure why I had to wait until I was ready to install them to clean them up. Also was turning the rear axle and it’s making noise not in a good way. I will pull the diff cover at some point, without seeing the oil I’m guessing that it may need a rebuild.
Also need to figure out what I need for brake booster stuff. I forgot that the ‘69 booster isn’t compatible with the ‘72 master.
Oh yeah and my foreman came in to inspect the control arms after torquing
Old 12-12-2021, 09:45 AM   #43
Getter-Done
Getter-Done's Avatar
Well did the foreman approve?
My Grandpa had a key pouch just like that.
The floorpan under the seat looks as it did from the factory.
84 Chevy K-20
Old 12-13-2021, 01:26 AM   #44
68bowtie
68bowtie's Avatar
That’s pretty damn clean inside the cab. Looking good.
What’s the plan for the interior pieces (floor mat, steering wheel, etc)? Just cleaning up, replacing with new/nice used, etc.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Project "Blue Bomb" (70 c30 blue original paint refresh)
Project "Vitamin C" (71 c10 orange original paint refresh)
Old 12-13-2021, 10:59 AM   #45
Ol Blue K20
Nice find on the keys, I like those old key pouches. It looks like an original key too.
Dale
Old 12-13-2021, 11:58 AM   #46
chev-obsession
The foreman approved only because he wanted to go back home
Thank you, it’s kind of scratched up from all of the extra tools he had under the seat but I didn’t think it was too bad. There are 4 holes from the auxiliary tank valve that I plan to weld up before the seat goes back in.
Thank you!
As of right now I am just going to clean up what is there. I will get a better passenger side sun visor or have that one re-sew’n. At some point after the truck is running, detail the interior and use some simple green to give everything a good scrubbing. On the off chance I find a nice OEM blue steering wheel and dash pad for reasonable then I probably won’t replace what I have. As for the floor mats, I’m not sure if I clean to clean them up or not. The drivers side is kind of torn up but a floor mat would cover it well and do a better job.
I would like to reseal the wing windows, glass runs and doors… at some point, after I get the truck running and driving. The windshield and back window rubber looks to be in good shape and if they don’t leak then I won’t mess with them.
Yes I was more than pleased when I found them! I’m fairly certain the other keys go to the auxiliary gas tank, camper door and storage compartments. I might just keep the little pouch to give the truck the full grandpa effect.
1965 c/10 swb
1969 c/10 lwb
Old 12-13-2021, 12:12 PM   #47
May70
May70's Avatar
Thats a cool truck and camper!
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 12-13-2021, 12:41 PM   #48
LT7A
Very cool that you found that truck and could give it the attention it needs. Thanks for detailing your efforts and I look forward to following along.
Old 12-13-2021, 11:53 PM   #49
68bowtie
68bowtie's Avatar
Awesome, glad to hear it. It’s really satisfying to refresh the original stuff. I bet that mat will clean up nicely. Nothing like that OE fit.
Old 12-14-2021, 03:06 AM   #50
chev-obsession
Thanks guys, I enjoy sharing this stuff with people who appreciate these trucks and the work to get them going again.
Yes I couldn’t agree more on the OE fit! It should clean up well with some oxy clean and the Hotsy!
Speaking of OE fit… I saved the rubber grommet from the fuel tank filler neck. My neighbor restores vintage motorcycles and has a trick for anything you might ever need fixed or repaired. One day I was over at his place and he was bragging about how he was softening a rubber intake boot. In the back of my mind I’m thinking “yeah, what kind of snake oil did you find on an infomercial?” Lol
Turns out he runs the rubber pieces through a “Vapor Hone” to clean them well, then soaks them in wintergreen oil and alcohol mixture and it works very well at softening old brittle rubber pieces. I had never heard of it before and I’m impressed to say the least. Since the rubber grommet on the fuel filler came out undamaged for the most part I had him give it a soak for half a day and it came out great. Good enough to put back on the truck. Also it smells like wintergreen/peppermint so it’ll be a nice “air freshener” if you will
Also I repainted (powder coated) a K5 blazer emblem that I found at a junkyard. I was going to put it on my tool box but wanted it to have a fresh paint job. I think it turned out fairly nice, a couple little blemishes that I will work out on my next fine detail job. Also wish the yellow was darker but that’s all I had. The chrome is fairly decent and not pitting so it went through the neighbors “Vapor Hone” with the fuel filler grommet.
1965 c/10 swb
1969 c/10 lwb
