08-29-2021, 06:51 AM | #26 |
Re: My GMC re-restoration
Great build and write up! I’m following along.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
09-11-2021, 08:54 AM | #27 |
Active Member
Exhaust is done. Bumper back on. It’s a running and driving truck now. Need to shim and align the bed/cab better then move on to paint/body
09-11-2021, 09:14 AM | #28 |
Mr. Cheyenne
Love your shop, I'd love to have a wood bed and stainless steel exhaust! Perhaps I could just drop by and you could sort me out! LOL
Great work and that green is the only color I like better than my Bronze (but I do like my white with it).
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
09-11-2021, 09:18 AM | #29 |
Mr. Cheyenne
So you were just able to upgrade the stock rear end 3.08 with the 3.73/locker stuff? I been wondering about a upgrade like that myself.
09-12-2021, 06:30 PM | #30 |
Active Member
Thanks for the feedback. Yea the 3.73 and locker is a pretty simple upgrade if you know how to do gears. I’ve done a few sets now. Just time consuming if you don’t do them all the time. Mine took 3-4 hours or so
10-04-2021, 04:34 PM | #31 | |
What rear rotors did you use? Did you have to machine the center bore on the rotors for the front or rear? |
10-04-2021, 07:03 PM | #32 | |
Active Member
Rear rotors are 330 mm Durango as well |
10-04-2021, 07:42 PM | #33 |
Awesome. I am going to look into the same. I think that this may be the most practical brake set up I've seen. Really nice build so far. I'm excited to see how you finish it off! Thanks for the replies.
10-05-2021, 01:27 PM | #34 |
Nice job! We are in similar spots. My truck was a little rougher to begin with, but the build directions and priorities are similar. I just got mine back on the road after doing the suspension, tank, and interior (among just about everything else).
I'm going to be redoing my exhaust shortly. The stainless tubing should show up today. That's an interesting choice about under the axle. Does the four link not have much droop? To avoid this issue, I plan to exit in front of the tire. |
10-06-2021, 09:24 AM | #35 | |
Active Member
11-18-2021, 03:48 PM | #36 |
Any more updates on this build? Did you ever install NVU gauges or PB hood hinges. Interested in the install and feedback on both of those pieces.
11-23-2021, 08:24 PM | #37 | |
Active Member
I have the NVU gauges installed. Work perfect. My only issue is I ran my tach wire in my main wiring bundle do it is catching some interference. I’ll fix that when I rewire it |
12-20-2022, 11:03 PM | #38 |
Active Member
Took a long break to finish a couple other trucks but now I’m going again. Also moved and had to setup a new shop. A bit smaller but functional
Had to rework a new bedside to match the tailgate. Love repop parts New to me OEM doors. No rust. Cost me some $$$ but worth it. Fitment is way better than the aftermarket ones I had |
02-02-2023, 07:48 PM | #39 |
Active Member
Enough upside down photos
Got the front end back on. Good gaps, and doors open/code easily with GMC Paul’s push on weatherstrip Also got the grille fit. What a pain. Had to move the mounts on the drivers side because it was shifted 3/8” to the passenger side. Also had to break the spot welds holding the headlights in and reweld to center them in the trim Got the vintage air condenser in |
02-02-2023, 07:50 PM | #40 |
Active Member
Got started on the under hood filler panels after I installed the porterbuilt hood hinges
Also mounted the battery under the bed on a custom drop down mechanism I designed |
02-03-2023, 09:20 AM | #41 |
Any time someone moves a battery to that position I like to remind them.....
Be sure to build a shield of some type to protect it from mud, tire rubber chunks, rocks, etc. Ask me how I know....lol. |
02-03-2023, 12:11 PM | #42 |
Do you have a picture of your battery shield? I'm in the same boat
My 1970 C10 ChassisFab LWB to SWB Build Thread |
02-04-2023, 07:58 PM | #43 |
No pics. It was actually on a Willys wagon. I ended up moving the battery inside the frame rail on it as I found some room.
02-17-2023, 12:27 PM | #44 |
Active Member
Yep its on the agenda. Shouldn't take too much. Plan is to have a simple formed stainless shield
