02-18-2013, 12:21 AM | #1 |
Going from 350 to 454
1967 C30 pickup with 350 4 bolt main, RV cam, Holley 650,HEI and headers with SM465 and Dana60 and keeping it in truck. Swapping in 454 .30 over, roller cam, Edlebrock 750 carb, high rise intake, Sanderson headers.
02-18-2013, 07:03 AM | #2 |
Re: Going from 350 to 454
Sounds like that will make one mean puller. Good luck.
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
02-18-2013, 01:14 PM | #3 |
350 is going in my 78 Blazer. Ive had the 67 C30 since i was 14.
02-18-2013, 10:07 PM | #4 |
got any pics of your c 30. i
02-18-2013, 10:25 PM | #5 |
Do you need different motor mounts for the 454?
Dan 1968 Longbed Stepside C10 |
02-18-2013, 10:25 PM | #6 |
I hope you would also consider upgrading the brakes some while your at it. I see that the truck has non power brakes and probably the drum drum type although I didnt look for the dist block to see if there was one or not for the disc brakes, I know it will stop but it would be a lot safer if you had some good brakes and stuff on there plus it will make it a lot more fun to drive. I know there are a lot on here with big blocks and real strong small blocks with drum drum setups without power so don't flame me I just want to point out the safty aspect of the hobby It is not near as much fun if someone gets hurt or we lose a truck because of to much power to stop or steer type of thing. I'm just saying have fun make resonable power and be safe. It is the dad coming out in me I guess. Jim
02-18-2013, 10:32 PM | #7 |
Looks good! Where did you get those tubular uper control arms? I thought they only made those for 1/2 tons. Do you know the Waren's? I work with Chris at Sears.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
02-18-2013, 10:53 PM | #8 |
02-18-2013, 10:55 PM | #9 | |
02-18-2013, 11:03 PM | #10 |
:P Not exactly what I was getting at :P
Is the swap from the 350 to the 454 a direct swap? Or does it require one to obtain different motor mounts for the big block?
02-18-2013, 11:12 PM | #11 |
Two projects of mine 67' C30 and 78 Blazer. Both are donating to each other.
02-18-2013, 11:18 PM | #12 |
That pic is of my 78 Blazer(Texas Truck) and the Performance brakes and arms are CCP parts. Yea i know Christopher Waren, I went to school with him.
02-18-2013, 11:19 PM | #13 |
02-19-2013, 12:32 AM | #14 |
Vintage 4x4s
The mounts are different for a big block. The steel parts and sometimes with cracked rubber clamshells usually sell for 100 or so a pair used. Then you have to get the clamshells new or revulcanized.
Clean c30, throw a bed on it and you're set.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-19-2013, 05:43 PM | #15 |
Thanks! Took it down to the chassis and restrenghtened the cab mounts, redid all the body work, and put the cab on, painted it inside and out and it all came back together smoothly. I have a flatbed im puttin on it.
02-19-2013, 06:53 PM | #16 |
clean trucks.
02-19-2013, 09:03 PM | #17 |
looks like you have several toys.....keep us posted on your build. have fun with them..
02-20-2013, 12:31 AM | #18 |
