Old 04-04-2023, 11:25 PM   #1
sixty8HDC30
The revival and documentation of my 1968 c30
This is my 1968 Chevy c30 that I purchased this last September.
My plans for it are to keep it all original, fix what is broken and drive it.
Here it is at its former resting place before coming home.
sixty8HDC30 is offline   Reply With Quote
Old 04-04-2023, 11:33 PM   #2
sixty8HDC30
Re: The revival and documentation of my 1968 c30
I need to figure out a better way to format my posts and post pics.
Here are some more of getting it home.
Old 04-04-2023, 11:36 PM   #3
cornerstone
cornerstone's Avatar
Yeah buddy! I like your plan and will be looking forward to updates. I'm curious, does your truck use the 20" widowmaker rims? My C-50 does.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 04-04-2023, 11:45 PM   #4
sixty8HDC30
First thing I did when I got it home was start the cleaning process by removing the soiled and degraded(but ultra cool) seat cover and vacuuming up the majority of the mouse and rat droppings from the interior and under the hood.
Then I removed the rotten ply wood from the flat bed and pressure washed the original wood underneath, came out pretty nice.
Old 04-04-2023, 11:48 PM   #5
sixty8HDC30
I will try to make regular updates
Old 04-05-2023, 01:00 AM   #6
sixty8HDC30
It currently has 18” with lock rings and tubes on the front and the rear has 19.5” two piece wheels.
Old 04-05-2023, 01:10 AM   #7
68bowtie
68bowtie's Avatar
S
u
b
s
c
r
i
b
e
d
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
68bowtie is online now   Reply With Quote
Old 04-09-2023, 09:28 PM   #8
sixty8HDC30
Today I shoveled enough of the snow that I was able to drive it out if the upper yard and down to the flat driveway.
There’s plenty of in between but I figured might as well just update to where we are now.
Parts list of needs
Master cylinder
Wheel cylinders
In cab gas tank
Wiring to brake lights re done
Wants
Seat cover
Tune up parts
Brake/clutch pedal rubber pads
