11-01-2020, 10:06 AM | #1 |
Re: Stuttering Stanley
It's hard to see how much of the rust is just on the surface, but It's a personal choice for you to decide how nice you want it to be. I went for patching the areas that had holes all the way through and not replacing the entire floor. From what I've seen replacing the entire floor doesn't appear all that hard, as long as you are ok with full cab removal. That will give you the best result for sure... but again, personal choice.
I see your spid shows it came with a front tow hook, is it still there?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-01-2020, 12:45 PM | #2 |
If you do a full floor pan, don't buy the high hump. Buy the standard floor and just cut the hump out of it. You can reuse your current hump and bolt it on the regular pan.
High hump floorplan inner rockers are way off. My build thread shows details.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
11-01-2020, 09:15 PM | #3 | |
i was looking at a good floor liner (prob a thick rubber) and i seen a few different options asking if it was "high hump" or low..... is it just a matter of a shifter coming out of the floor? like all floor shift manuals and all 4wds will be high hump and 2wd auto or "3 on the tree" will be low hump?....because they have nothing coming out of the floor? |
11-01-2020, 09:09 PM | #4 | |
Tags |
4x4, 72 k10, sum-1103 |
