Old 05-19-2021, 05:13 PM   #1
mister.freeze
mister.freeze's Avatar
Drip rail deflectors
How do they work? I’ve not had any on the Fawkes for 22 years now, but the passenger side is starting to leak. I can’t, for the life of me, trace the source!
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 05-19-2021, 05:14 PM   #2
mister.freeze
Re: Drip rail deflectors
Pic
Old 05-19-2021, 07:54 PM   #3
truckster
truckster's Avatar
The drip deflector bridges the gap between the windshield frame and the top. It works pretty well. Make sure you put a bead of silicone on it before you install it.
Mine are pretty old and cracked, but my new Softopper should be here soon...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-20-2021, 10:51 AM   #4
mister.freeze
I've filled that gap with silicone in the past, without luck... Are those things magic?
Old 05-20-2021, 12:38 PM   #5
truckster
truckster's Avatar
They're not magic, but if you run a bead of RTV where they contact the top/pillar they work pretty well. I'll still get an occasional drip, but not nearly as much as I did without them.
