01-22-2017, 11:57 PM | #1 |
67 Stepside Build
Adding my build to the list. Bought a 67 Stepside in October with a trashed 350 (see pics below) and a Muncie M20. Pulled out the motor and bought a 6.0L LQ from a 2002 with 317 heads. Not that into the flame job, but I can live with it for now. Here are the details on what I am thinking for the rest of this build:
OK, that is all I can think of at this time. It is late and my brain is toast. Gotta get some ZZZZZ's. Looking forward to sharing the build and hearing your comments on my bullets above. Not locked down on anything quite yet so now is the time to throw out your opinions. Thanks! Last edited by BaroneDog; 12-14-2017 at 11:21 PM. Reason: Incorrect Title - No TKO |
11-26-2017, 10:28 PM | #2 |
Re: 67 Stepside Build
Looking for some advice from someone out there that has done a LS/T56 conversion in a 67, or similar, pickup with a stock crossmember as shown above. Trying to get a definite answer on whether or not the T56 bellhousing will clear the stock crossmember. I already did a test fit with the engine and bellhousing only and the bellhousing clears the crossmember by maybe an inch (see crummy photo below). However, I am not sure how much the T56 will have to be angled to fit and I am worried the crossmember might interfere.
Anyone have experience with this? Would be great if I could know for certain if it will clear before I try and install the engine with the T56. Oh, I am using the CPP engine stands and LX Innovations motor mount adapters that allow me to move the engine forward/backward. Currently I have them set to put the engine as far back as possible (see photo below). Thanks!!! Last edited by BaroneDog; 12-14-2017 at 11:22 PM. |
11-26-2017, 11:12 PM | #3 |
Well, this build has been sitting since the first post nearly a year ago. Got distracted with upgrades to my 63 Chevy II Wagon but now getting back to this! Updating my build list based on the components I have actually purchased and have started to install so this can be well documented....pending it all actually works out well!
Would be happy to hear any thoughts or recommendations. Thanks. Last edited by BaroneDog; 12-14-2017 at 11:22 PM. |
01-03-2018, 09:55 PM | #4 |
Just adding a few threads to this so all the build info is in one place.
These threads discuss cutting out the stock crossmember (the type up front near the bellhousing) as well as T56 shifter position: http://67-72chevytrucks.com/vboard/s...d.php?t=752631 http://67-72chevytrucks.com/vboard/s...d.php?t=753099 Lessons Learned: 1) Better off removing the crossmember even though it is a pain to cut out 2)An aftermarket T56 does NOT need a front shift kit to clear a bench seat This thread discusses header/frame clearance in my truck which appears to have wider top frame rails than later years. http://67-72chevytrucks.com/vboard/s...d.php?t=754045 Lesson Learned: That will come in a later post after this is solved Thanks. |
08-02-2018, 09:37 PM | #5 |
Re: 67 Stepside Build w/ LQ/LS and TKO Swaps
So the truck is on the road now. LQ/T56 conversion done. Hyd clutch. 4/6 drop. New wheels and tires. Power disc brakes in front. Cleaner engine bay. It was a busy winter and spring. Made some progress but still need to get rid of the flames...although sometimes I feel like they are growing on me. Body work might be next. Some pics of the progress.
08-02-2018, 10:13 PM | #6 |
Im going to build a 70 stepper in the distant future but would love to see more pics of yours .
08-03-2018, 07:00 AM | #7 |
Thanks for the interest. Here are a few more. Good luck with your build!
08-03-2018, 09:51 PM | #8 |
Looks nice. 15 inch wheels?
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
08-03-2018, 11:04 PM | #9 |
08-04-2018, 06:25 AM | #10 |
I really like the rallye wheel look. I am going to change mind to 16 or 17 " rallyes.
