05-06-2016, 12:57 PM | #1 |
4l80e not shifting, no speedo
Parked my 91 to swap the doors out for a power set and do a little work on the glow plug wiring. Everything went as I would expect but when I put the dash all back together and ran the truck it wont shift gears and my speedo stopped working. I changed the output speed sensor and there was no result. Before I throw anymore parts at it I'd like to just make sure I'm barking up the right tree. Can anyone give me a troubleshooting process to follow, to identify my problem? I'd really appreciate any help.
I also noticed that the wires from the output sensor had been repaired in the past near the trans, is there any reason not to re-run them from sensor all the way to pcm to just ensure they do what they're supposed to? Edit to add: the truck is an R model so it's a square body and has a square body gauge cluster if it matters.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually 1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr 1991 CR500 (95 Burb wouldn't stop catching fire ) |
05-07-2016, 11:07 AM | #2 |
Re: 4l80e not shifting, no speedo
There are two speed sensors, one cheap and one expense. Could it be from the disconnect/connect taking the dash out? Is it well connected? I'd check into that first, if you haven't already. Yeah, you could run a wire end to end with soldered splices or just splice it there correctly.
05-10-2016, 07:59 PM | #3 |
swapped both sensors now and still nothing so I'm leaning heavily toward wiring issues. It's very unlikely I disturbed anything near the PCM when running the wires but it is entirely possible that I damaged the speedometer/gauge housing bc its a tight fit going in or out. Does the speedometer relay info to the transmission PCM or is the speedo info relayed from the PCM?
05-11-2016, 07:42 PM | #4 |
I'm lost on that part. My next place to look would be at the connections, as well. Maybe if no one offers good info here you could try the Engine/Drivetrain section. Being not year-specific and full of techs you may have better luck there.
05-11-2016, 08:44 PM | #5 |
The Speedometer, PCM, ABS, & Cruise get their VSS signals from the DRAC Module, The Output VSS is wired directly to the DRAC Module.
The DRAC basically converts the AC-Sine wave signal generated by the VSS, And converts it to a DC-Square wave signal that can be read by the above components. GM moved around the location of the DRAC a few times during Square Body production, If memory serves it's between the Steering Column & Ashtray under the dash, (The below location diagram agrees) BUT, Don't take this as gospel. Locate the Module & make sure its plugged in, The diagram shows a few inline connectors, So check those also. |
05-14-2016, 04:16 PM | #6 |
When I did the door wiring I noticed the heater controls had a short on the wiring. To be safe i removed the fuse. GM in a fit of judgement of and wisdom decided to use the heater circuit to power the DRAC module. Unplugged the heater control and replaced the fuse, works perfect. Thanks guys.
05-14-2016, 06:55 PM | #7 |
I learned something here. Glad you get her readin' and shiftin'.
