Old 05-06-2018, 07:33 AM   #1
mgb
mgb's Avatar
bucket don't line up in cradle
Bucket on drivers side sits to the outside of middle about 1/2 in. It appears that the adjusters holes are off to the right. Do I extend these slots, or what are my options? '68 stepside
mgb is offline   Reply With Quote
Old 05-06-2018, 12:26 PM   #2
Jrainman
Jrainman's Avatar
Re: bucket don't line up in cradle
If you are saying you have original c10 bucket seats ,this would be correct the c 10 bucket seats have a different hole pattern then a c10 bech seat. If you look close enough there might be indentions for the bucket seat bracket location, I have seen this on one cab that I aquired for parts. there is also the underside brace , but i dont remember if they have one specific for buckets , maybe someone else might chime in on that I am not that familar on the subject about the bracing.
Jrainman is offline   Reply With Quote
Old 05-06-2018, 07:21 PM   #3
mgb
mgb's Avatar
No, actually I'm talking about the headlight bucket. The bucket doesn't sit in the radiator cradle right. This causes the light to sit too far to the right
Old 10-18-2020, 10:56 AM   #4
old51sedan
old51sedan's Avatar
Don't feel bad, I think most of us found out shortly after we got married that we flunked mind reading, I know I did big time as I thought he was talking about seats also. This is where pictures come in handy....
old51sedan is offline   Reply With Quote
Old 10-18-2020, 11:01 AM   #5
HO455
HO455's Avatar
I too jumped on the seat bandwagon.
Definitely need some pictures on this one.
And is there any aftermarket sheet metal involved?
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 10-18-2020, 11:44 AM   #6
gmc684x4
Right side bucket on left side ?
Bucket upside down ?
Gmc bucket on a chevy vise versa
gmc684x4 is offline   Reply With Quote
Old 10-18-2020, 11:55 AM   #7
LockDoc
The Original Thread Killer
LockDoc's Avatar
I am an advocate of bringing up older threads but I am betting the OP has this problem solved by now.....
LockDoc
Leon
Old 10-18-2020, 01:43 PM   #8
Ol Blue K20
truck of four colors!
Ol Blue K20's Avatar
LockDoc
I didn't even notice it was old..
Dale
XNGH ECV Sam Brannan 1004
Old 10-18-2020, 03:12 PM   #9
gmc684x4
Thanks doc i did not notice the old date either ��
Old 10-18-2020, 03:43 PM   #10
HO455
HO455's Avatar
LockDoc
Man! That Leon is still the quickest pony on the track!
Old 10-19-2020, 09:24 AM   #11
old51sedan
old51sedan's Avatar
He sure is, I didn't see that either....
Old 10-19-2020, 09:47 AM   #12
LockDoc
LockDoc's Avatar
I'm not sure what even made me look at the date. I usually just jump on the band wagon too.
LockDoc
Leon
Old 10-19-2020, 02:33 PM   #13
Custom 68
D.U.F. Member
Custom 68's Avatar
I would still like to know the outcome...lol
Dave
1968 Custom Chevy with turbo charged 5.3 gen III T56 six speed swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-19-2020, 05:27 PM   #14
Davidf
Well, since we are talking headlight buckets, I don't think the bucket alignment is affected if you swap sides or try to use a left on the right or vise versa. The only issue that causes is the headlight won't be rotated correctly in the bucket. My truck somehow had two RH buckets. I simply make new headlight notices in on of the buckets to make it a LH bucket.
But, the bucket alignment left to right within the grille was never a problem. The PO simply retained the headlight in place with the alignment tabs outside the slots in the bucket.
Davidf is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
