12-06-2021, 05:23 PM | #1 |
Bottom door hinge - bottom tab angle to door?
I'm starting bodywork on my '78 C10. The hinges (not just the bushings) were worn out so I bought replacements. The new ones don't have an angle on the bottom tab of the bottom hinge where it's supposed to attach to the door. Is it supposed to be bent to meet the door or did my original door and hinge bend that much over time?
In this picture the bottom hinge is bolted flat to the door jamb, the door is bolted flat to the top tab on the hinge and this is what the bottom tab of the hinge looks like at the door. I'm assuming there needs to be a bit of bend on the hinge tab but, on the other hand, it doesn't seem like there should be an indent in the door at that location.
Evan B. |
12-06-2021, 07:30 PM | #2 |
Re: Bottom door hinge - bottom tab angle to door?
Mine was like that also. But your going to have to use spacers, so that bend isn’t going to matter.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
12-06-2021, 09:16 PM | #3 |
Thanks. Where did you add spacers and what did you use?
Evan B. |
12-06-2021, 09:37 PM | #4 |
I reused the spacers that were there from the factory. They go between the hinge and the door. I don’t think I have any pictures of them. But I can get some pics if you need.
12-06-2021, 10:08 PM | #5 | |
Are they kind of like these from LMC?
Evan B. |
12-06-2021, 10:27 PM | #6 |
Yep looks like them.
12-07-2021, 01:00 AM | #7 |
I've only seen the spacers used for the fenders. Never from the factory have I seen spacers used for the door hinges.
12-07-2021, 01:01 AM | #8 | |
12-07-2021, 01:05 AM | #9 |
The bushing holes were wallowed out. It's my understanding new bushings can only help so much when the hole they're in is out of round.
Evan B. |
12-07-2021, 02:20 AM | #10 |
12-07-2021, 02:21 AM | #11 |
Try to find OEM fender shims. They have a handle.
12-07-2021, 09:34 AM | #12 | |
Every truck is different. I have shims that were on the doors and fenders. When I replaced the hinges, I was hoping to not have to reuse the shims, but I did. I had to use them to help get the door fully aligned. And all that took time & patience.
12-07-2021, 01:31 PM | #13 | |
12-07-2021, 04:29 PM | #14 |
Got them from ClassicParts.
12-07-2021, 05:16 PM | #15 |
They make oversized bushings. Plus I’ve welded several up on the 88-98 body style, as those are welded to the body. Not that hard to do
