Old 07-12-2019, 08:55 AM   #26
LT7A
Re: Grandpa's OG 1978
Good progress! It looks like your door panels and armrests came out really well. I find that I am content to do cleaning, patching, painting, gluing or whatever it takes to use original stuff. No judgment on anyone else's approach, but I don't mind cracks and wear and tear if I can have original parts.
Old 07-12-2019, 09:54 AM   #27
olrosa
olrosa's Avatar
OG parts are the way to go if you can. For sure!
olrosa is offline   Reply With Quote
Old 03-17-2022, 07:34 PM   #28
olrosa
olrosa's Avatar
Well its been quite awhile. I moved up to Washington state and sold the truck because I had no where to put it.
The new owner modified it a bit and still had the truck. I couldn't stand it. i bought it back last week. LOL.
Going to pick it up soon. I'll send some new pictures.... The bed is a lot shorter now
Old 03-18-2022, 10:56 AM   #29
LT7A
I really liked this one - glad you got it back. And welcome to the state!
Old 03-18-2022, 02:54 PM   #30
olrosa
olrosa's Avatar
Thank you!
Old 03-18-2022, 02:55 PM   #31
olrosa
olrosa's Avatar
Here is where the bed was cut.
Old 03-21-2022, 07:18 AM   #32
LEEVON
LEEVON's Avatar
Sweet, let's see the "new" old shortbed truck in all her glory!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-21-2022, 11:32 AM   #33
olrosa
olrosa's Avatar
I haven't picked it up yet. But here it is currently.
Old 03-21-2022, 02:56 PM   #34
LEEVON
LEEVON's Avatar
Looks great! How did you lower it? Is that down at Coyote Customs in Oklahoma? I thought I recognized his cuts...
Old 03-21-2022, 04:24 PM   #35
olrosa
olrosa's Avatar
McGaughy lowering kit, spindles, springs, C notch
it was done in Oregon, not OK. I think a lot of people are doing it this way.
Old 03-29-2022, 10:59 AM   #36
olrosa
olrosa's Avatar
Starting to get it cleaned up again. i am not sure if I like the sport bumper. Most people prefer them, but I think i will put the original bumper back on and see what that looks like. I like it better because that's what the truck came with originally.
Also I am going to raise it up an inch. Just a little to low to drive without being nervous about every bump.
Maybe in a couple years i will build this into a pro-street with air ride truck???
Old 04-06-2022, 03:37 PM   #37
TotallyHucked
TotallyHucked's Avatar
Very cool truck, glad you got it back! It looks great right there, I wouldn't raise it up personally. I drove my square at ~5/6 for a long time with no issue on rallies and now I'm 5/8 on 20s and take it everywhere without issue
TotallyHucked is offline   Reply With Quote
Old 05-15-2022, 12:21 PM   #38
olrosa
olrosa's Avatar
I’ve been doing a few things here and there. Cleaning, painting trim (not to nice though), and installing some mild Slosh Tubz. The tires rubbed on some bumps. I couldn’t stand. And I’ve used Slosh Tubz before. Very high quality.
Old 05-15-2022, 12:22 PM   #39
olrosa
olrosa's Avatar
New BFG’s
Old 05-15-2022, 12:25 PM   #40
olrosa
olrosa's Avatar
Rear disk brakes
Old 05-15-2022, 02:09 PM   #41
LT7A
It's looking sharp. Good upgrades for making it nice to drive.
Old 07-26-2022, 05:28 PM   #42
olrosa
olrosa's Avatar
Got a used LS for “the Conductor”. My grandpa was a Conductor on the railroad.
BTR stage II cam, lifters/springs , DOD delete.
Old 07-26-2022, 05:30 PM   #43
olrosa
olrosa's Avatar
I be painting everything to match the body color of the truck. Here are some parts I finished the other day. I will paint the block/heads etc soon.
Old 07-26-2022, 05:33 PM   #44
olrosa
olrosa's Avatar
Also received my QA1 front coil over suspension. I will install it this winter. Same setup as I used on my ‘66.
It was go good, I had to use it again.
I want this truck to be an everyday “shop truck” type of driver that anyone can get in and drive without any hassles.
Hope y’all like it
Old 07-27-2022, 02:29 PM   #45
olrosa
olrosa's Avatar
Couldn’t wait. Got the block painted
Old 12-20-2022, 09:33 PM   #46
olrosa
olrosa's Avatar
Moving on to the front suspension. Full QA1 with their crossmember as well.
Old 12-20-2022, 09:34 PM   #47
olrosa
olrosa's Avatar
I also got the valve cover scripts.
Old 12-22-2022, 02:36 PM   #48
Hart_Rod
Hart_Rod's Avatar
Seth - Everything looks good! I've been debating on using the QA1 setup for my 84, but haven't quite pulled the trigger. Where did you source it from? Take care and post more pics!
Hart_Rod is online now   Reply With Quote
Old 12-22-2022, 07:49 PM   #49
olrosa
olrosa's Avatar
Thank you Rob. I got the Crossmember from AZperformance. I should have it all buttoned up in a couple weeks. Just haven't had much time with the holidays. I wanted it for the additional 2" of ground clearance. And the rack and pinion steering helps too lol
Old 12-25-2022, 02:55 PM   #50
olrosa
olrosa's Avatar
All bolted up.
