04-23-2022, 01:30 AM | #1 |
Driveshaft Center Support Bearing
Is it possible to replace the center carrier bearing on a 2 piece driveshaft without a press? I don't have one and the nearest shop isn't very near.
Watched my dad replace one when I was about 10 years old. We didn't have a press and I don't remember if he heated it or beat it into submission. I haven't pulled it because I don't have a plan yet. Thanks
Repairing and driving old trucks is an analog experience. No computers or sensors and they can be fixed with basic hand tools |
04-23-2022, 01:50 AM | #2 |
Re: Driveshaft Center Support Bearing
Rent a puller from the auto parts store or go to HF https://www.harborfreight.com/bearin...6c35a5814f1809
Tap the new one on with a piece of pipe or use a drift. Heating the new bearing can make installation easier.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-23-2022, 01:29 PM | #3 |
Fabricate till you "puke"
Being a back yard mechanic, not many tools on hand....I layed the bearing down on an anvil smashed the outer ring with a 5 lb hammer (do wear a face guard for this)! After that, I took a die grinder & cut most of the way through on the inner ring, then smacked it with a cold chisel/hammer. I would bet that your DAD beat it on with a chunk of pipe. That is the way I do it....understand that you can warm that bearing up, but I would not. That bearing is sealed with grease......too hot & it will fail, do to the seals. Just a backyard way....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-23-2022, 06:16 PM | #4 |
Thank you very much, Longhorn. The way you described it sounds EXACTLY how my dad would have done it and probably did. Too many years have passed and I don't remember all but I know a big hammer was involved and he was not happy.
04-24-2022, 07:08 PM | #5 |
Yes, I will bet that he had a few choice words....I know that I did But you know that what hits me the hardest, was an old man with few tools....still got the job done Longhorn
04-26-2022, 11:47 AM | #6 |
ive done it without a press just make you you mark teh shafts so that are clocked right when it goes back in
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-26-2022, 03:18 PM | #7 |
2nd that longhorn
05-02-2022, 03:53 PM | #8 |
There may be one or two fingers that do not typically come with the new bearing. They are located on each side of the bearing.
If you want to save them you will have to pull, or press, the bearing. The may be gone already? I searched the assembly for Prop shaft and failed to find a break-down of the center bearing. |
05-06-2022, 12:09 PM | #9 |
I just did this at home, it’s fairly simple. I was able to get mine off with a small 3 jaw puller, reinstalled with a 1.25” pipe. Just be careful when reinstalling and to support the opposite end of the drive shaft so you don’t damage the bores for the u joint caps
1965 c/10 swb 1969 c/10 lwb |
