04-12-2021, 02:54 PM | #1 |
Help 5x4.75 front and rear
I Aquired a new to me 67 c10.. affectionately refered to as good enough. As the previous owner this was his motto.... i did this to the truck... not right but good enough!!!!. there was already a front disk converion done and all wheels are 5 bolt.. it wasn't until i got some vintage wheels and tried to put them on that the truck is 5x4.75 all the way around... i understand the front is easy to do this but what possibly did he do to the rear to get drum brakes 5x4.75?????
04-12-2021, 03:06 PM | #2 |
Re: Help 5x4.75 front and rear
Passenger car rear . My Chevelle had a 12 bolt drill 5x4.75 it now has a 9 inch
04-12-2021, 03:21 PM | #3 |
I have ordered lowering springs spindles and swaybars front and rear any idea if this will cause me any grief with a swapped rear? .. why would you swap it to car rear and not put a posi in it at the same time??? Is this more good enough?
04-12-2021, 03:35 PM | #4 |
Are you sure they’re 5x4.75?
Did you measure them? Post some pics of your wheels and your rearend. |
04-12-2021, 03:43 PM | #5 |
Yes i measured them. took center cap off. They are currently some sort of chev rally wheel with the center cap bolted to the wheel.. i haven't been under her yet and still have to figure a way to image host to post pics
04-12-2021, 03:59 PM | #6 |
Sound like truck rallies. 3 bolts hold the cap on.
Describe how you measured them. |
04-12-2021, 04:09 PM | #7 |
Measured center to center across 2 studs skipping 1 stud wheels are 15x8 yes 3 bolts/ slotted head screw
04-12-2021, 04:14 PM | #8 |
You measured wrong.
Outside of stud to centre of opposite stud is the way. That would make them 5x5. |
04-12-2021, 04:29 PM | #9 |
Re: Help 5x4.75 front and rear fixed by Geezer
Well crap!!@!! ( insert head dope slap here ) well now That explains EVERYTHING!!! GEEZER you da man
04-12-2021, 04:37 PM | #10 |
So then your truck is 5x5.
The rear axles were likely changed to match the front. There’s a kit made for that. Yours likely was swapped. |
04-12-2021, 04:42 PM | #11 |
thats much better and what I thought it was
04-12-2021, 04:54 PM | #12 |
Good looking truck.
My user name was used because when I joined up here I had a 67 gmc that was the 99th built. What you running for a drivetrain? |
04-12-2021, 05:15 PM | #13 |
283 3pd right now column shift moved to floor. have a 350 and t5 from s10 to go in.. eventually 383 stroker and auto
04-12-2021, 05:25 PM | #14 |
Mine was a 250 and 3ott that I Converted to 3 on the floor.
Pic here. Post #80. Almost same color as yours. It resides in Langley BC now but has a 327 and turbo 350 in it. https://67-72chevytrucks.com/vboard/...=281109&page=4 |
