05-20-2005, 05:17 PM | #1 |
Power Brake Booster Braces
Does anyone have a picture of their firewall with the Power Brake Booster mounted and the braces attached? I need to see where they attach to the firewall.
Thanks Rick / Ca. |
05-20-2005, 05:38 PM | #2 |
brace question
I know one bolts to one of the bolts for the emergency brake. The other maybe to the booster mount
05-20-2005, 06:53 PM | #3 |
Braces
Thanks for the quick reply.
Regards Rick |
05-20-2005, 07:06 PM | #4 |
Here are some pictures, note the 2 braces.
05-20-2005, 07:10 PM | #5 |
Found some more
05-20-2005, 07:18 PM | #6 |
Braces
Exactly what I needed.
Thanck You My truck came with Power Brakes, But never had the Braces on it. I'm replacing the booster, Master cyl. & brake lines and I thought I should make it right. Rick / Ca. |
05-20-2005, 09:56 PM | #7 |
Do you need to have both? I just have the top one on mine.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug |
05-20-2005, 11:08 PM | #8 |
its all about the +6 inches
I'm pretty sure the braces were only on 71 and 72...never seen them on anything older
05-21-2005, 10:34 AM | #9 |
Braces
That explanes it. My truck was a 70 origionally. I converted it over pretty much to a 72 over the years. And now for the brake booster.
Thanks Rick / Ca. |
05-21-2005, 03:38 PM | #10 | |||
Union Electrician
So do you have to use the brackets? Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
05-21-2005, 10:41 PM | #11 |
I don;t have any on mine and it works fine.
05-21-2005, 10:55 PM | #12 |
Braces
I've had my truck for 35yrs without them, so obviously you don't need them.
Gm must have put them on the 71 & 72's for some reason, so I thought I would add them. Rick / Ca. |
05-22-2005, 10:24 PM | #13 |
'Burban Legend
Rick, Braces At Your Age?
Heck, I didn't even know your teeth were CROOKED! HeHe! Must be workin' hard on that brake setup, haven't heard from you. Looks like I will be in the Valley in early AUG, I will let you know as plans firm up. Take care, The Rod
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
10-27-2014, 03:34 AM | #14 |
Re: Power Brake Booster Braces
I have recently performed the same brake system upgrade on my 68 k20. I had to find the 5&1/2 inch booster to firewall brackets from the j yard. While retrieving the brackets off of the 72 donor I noticed the two braces and decided to take them as well.
When I got the parts back I noticed there where no holes or studs on the firewall to mount them to. I was not able to see any photos on this thread for some reason. Does anyone have any or maybe some tips on drilling and fabrication to make them fit. |
10-27-2014, 02:23 PM | #15 | |
10-27-2014, 02:57 PM | #16 |
The booster is a dual diaphragm type but uses the stock braces.
10-27-2014, 04:37 PM | #17 |
blood type; Retumbo
damn you Fitz, you made me drool on my keyboard again
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
10-27-2014, 06:51 PM | #18 |
Thread Tools | |
Display Modes | |
