Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 60-66
Closed Thread
Old 04-07-2007, 10:02 PM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Wiring in Relays for your HEADLIGHTS
Here you go....A nice Diagram on HOW TO ADD RELAYS TO YOUR HEADLIGHT CIRCUIT.
It's actually a pretty basic install. The best place to mount the relays is next to the Horn relay area (LF fenderwell). I recommend replacing the power-wire from the battery to the horn relay with at least a 10 ga. wire. (If it's not already)
You can now run your fuse/breaker off of the power terminal of the Horn relay.
You can then unplug the headlight harness at the radiator support, and connect those wires to the relays, according to the diagram. You can use blade terminals to insert into stock harness, that way you won't need to cut your harness. (unless you want to).
The LO and HI relay output terminals (87) will now plug into the stock plug in the rad support.
You now have FULL BATTERY LOAD to your headlights...and as Bryan mention, have a cooler harness under the dash !!!!
Hope this Helps !!!
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline
Old 04-08-2007, 12:19 AM   #2
Captainfab
60-66 Nut
Re: Wiring in Relays for your HEADLIGHTS
Thanks for posting that wiring diagram ChiefRocka That'll be handy to have. Do you have any recomendations on what size fuse or breaker to run with this setup?
Captainfab is offline
Old 04-08-2007, 12:46 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The standard 30 amp relays, and a 30amp breaker would be the ideal system.
They have the 30 amp breakers with mounting brackets built in.
Just as metioned in another post...Hella or Bosch (not sure which) make a relay with a built in 30amp fuse/holder...Kinda cool
Although...running a breaker...is a much safer way.
Hope this helps
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Closed Thread
