Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-03-2007, 07:30 PM   #251
Frizzle Fry
Frizzle Fry's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Ok I've got some catching up to do on progress pics. Here's the rest of the air management:
This is the ECU for the Easy Street digital air management system. I suppose it's meant to be mounted to the frame because they made the harnesses so short you really don't have much choice. Since this is a Burb I was able to find a nice dry spot INSIDE the vehicle to mount it with barely enough slack in the harnesses.
Finalized the compressor wiring:
Here you can see the ECU and compressor relay:
Here it is with the ECU mounted behind the taillight (you can see the top mounting screw):
I ran the compressor power and ECU power wires up the D-pillar, in the track above the windows and down the A-pillar. The 12 gauge comp power goes straight to my stereo circuit breaker which is fed by 0-gauge from the batt:
Frizzle Fry is offline   Reply With Quote
Old 07-03-2007, 07:41 PM   #252
Frizzle Fry
Start on the Notch:
First I removed the shock crossmember (kinda dark, I know):
I had previously welded in this crossmember in front of the tank to add frame rigidity. At this point I though about removing it but decided there was no need o take it out. I would just have to make the notch fit around it:
Positioning upper plates; I used this bar to set them level in reference to each other:
Here's where the driver's side ended up You can see where the frame had to be trimmed to get the inner plate to side flat against the rail:
Test fitting the inner plate after making a template and trimming it to fit around that crossmember:
Burned it in:
Welded the inside as well while I had access:
Old 07-03-2007, 07:44 PM   #253
krue
Designated A-hole!
krue's Avatar
You're kicking ass with this one!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-03-2007, 09:48 PM   #254
Frizzle Fry
The passenger side needed a tiny corner cut off to fit in front of that crossmember (sorry no pics of that).
The outer plates were trimmed slightly to match the angles of the lower rails:
...and here the OG frame section is gone and the lower plates are in:
Old 07-03-2007, 09:55 PM   #255
pat
pat's Avatar
Nice work. Do you have a bender, or do you just use the vise and hammer technique like I would?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 07-04-2007, 12:05 AM   #256
Frizzle Fry
Thanks Krue
Pat, it was a pre-made kit from KP Components Link here ...and yes, I do the vice/hammer thing too KP uses a press brake to bend these and they fit very well (all frames are slightly different so they're as close as they can be). Sure I could have made it, but skipping the that headache was well worth the money to me.
Old 07-04-2007, 12:32 AM   #257
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
nice work, this is one of the threads that i keep up with, i need to learn how to weld and fabricate as well as you!
tommie is offline   Reply With Quote
Old 07-04-2007, 12:41 AM   #258
Frizzle Fry
Next I cut/drilled the holes for the bags:
POR-15'd the areas where the bags mount (will do rest later):
Old 07-04-2007, 01:24 AM   #259
Frizzle Fry
You can see in that last pic how close the drive shaft is to the floor That's with the axle tube basically sitting where the frame used to be (no lower than without a notch).
So... I'll be making a tunnel including modifying the trailing arm crossmember and two rear floor braces
Because of this I've made some wood blocks to prevent it from going any lower than that for now.
Old 07-04-2007, 01:33 AM   #260
Frizzle Fry
Next the cross-brace/bridge/shock-mount:
I stuck with the keep it simple concept and made up this using lower mounts from suicide doors (nice pieces), and some of their studs in a 2x2 at the top:
The camera is angled here but the shocks are very close to parallel with the bags (FBSS):
The bottom of the right shock is just dirty... I'll get a better shot of this:
Old 07-04-2007, 01:37 AM   #261
Frizzle Fry
So, without the front bags in yet I set the rear where I think it looks good vs. the front (tiny rake) and snapped some shots. This is pretty close to full lift in the rear With the current shocks it'll come down about 6" from this point
Down a little more... Still has a LOT more to go:
Old 07-04-2007, 03:29 AM   #262
krue
Designated A-hole!
krue's Avatar
www.daveramsey.com
Old 07-04-2007, 07:29 AM   #263
5150
C10 Club Tennessee
5150's Avatar
Looks awesome!!!!!
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 07-04-2007, 07:35 AM   #264
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Are you keeping those wheels? Or are you going to go bigger?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-04-2007, 02:48 PM   #265
Frizzle Fry
20/22 Coy C5
Old 07-04-2007, 03:47 PM   #266
LiveWire64
LiveWire64's Avatar
Awesome build!! Can't wait to see this one finished.
I have a question on your flip up rear door. How does it latch or lock when it's closed? Thanks & keep up your great work. Brad
55 Chevy small window.
66 FJ40 LandCruiser.
64 Chevy Van,350/350
72 Chevy 10 Van,short wb,454
78 Chevy 10 Van,short wb,350
72 Chevy Malibu 350.
77 Chevy Suburban. Silverado 20 Trailering Special.454,turbo400.
LiveWire64 is offline   Reply With Quote
Old 07-04-2007, 09:26 PM   #267
Frizzle Fry
I'll tell ya, but it'll cost either the 55 or the FJ
Alright I guess that's a little steep The original tailgate latches work just like normal. The gate is basically vertical when they latch just like when it's hinged from the bottom. Simplicity
Old 07-05-2007, 07:49 PM   #268
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I can't wait to see it sitting on the ground. Lookin good
LOW DOUGH is offline   Reply With Quote
Old 07-09-2007, 09:04 PM   #269
LiveWire64
LiveWire64's Avatar
Smile Re: Joined the Short Wheelbase Club *69 Tahoe Project*
I saw a 65? Chevy panel truck yesterday at the Brothers show & it's owner had made the rear tailgate & window a 1-piece lift-up kinda like what you are doing. He used the stock upper hinges for that make & year of panel. He did say that he had to modify the rain gutter some in the back so the door wouldn't hit it when it opened. Also mentioned the hinges are hard to find.
I know you were thinking of making your own hinges. Thought I would pass this hinge idea to you. Maybe you have already explored this idea. Keep us posted,Brad
Old 07-10-2007, 11:46 AM   #270
Frizzle Fry
Hmmm... very interesting. I appreciate the info. It's cool that you noticed and thought of this build I'll have to post a question about it over on the 60-66 board.
Old 07-11-2007, 01:58 PM   #271
JayG
Formerly ADHDCARGUY
JayG's Avatar
Awesome build! I just spent my entire lunchtime reading this!
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 07-11-2007, 07:23 PM   #272
Frizzle Fry
Thanks man, it's fun. I think I have a little ADHD myself You can see it in the way I skip around on this project
Old 07-11-2007, 07:25 PM   #273
Frizzle Fry
Check it out, the 60-66 guys came through with some pics:
I'm gonna have to try to get my hands on some of those
Old 07-11-2007, 07:46 PM   #274
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
May try to get a repo set if they repo them yet???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-11-2007, 08:59 PM   #275
hgs_notes
GEARHEAD
hgs_notes's Avatar
I thought I may have had a line on those hinges for you, but I looked at the old pictures I took and it had barn doors. Sorry
hgs_notes is offline   Reply With Quote
Thread Tools
Display Modes
