Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 06-15-2007, 02:16 PM   #1
67ChevyRedneck
67ChevyRedneck's Avatar
Rebuild you A/C controller
For those who want to add A/C to their trucks using a vintage air or other kit that utilizes a stock A/C controller, or you just want to restore your own back to functionality again... here's some tips on how to redo one. I have about $65 in this. $20 for a used A/C controller with broken arms, about $30 for the "repair kit" and $13 for a new fan switch from LMC. I also wanted to be a little different, so I did a "white face" one to match my dash. It's still cheaper than buying a rebuilt one for $120+. Also, if you don't have broken arms and a good fan switch, you can do this pretty cheap
Here goes:
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline
Old 06-15-2007, 02:21 PM   #2
67ChevyRedneck
Re: Rebuild you A/C controller
Remove the two screws from the vacuum switch and remove it.
Remove the two screws from the fan speed switch and remove it as well. Don't lose the screws like I did
*as a side note, I had a spare parts controller to "copy from" because I did forget how stuff went back together, hopefully this will help others. Too bad I didn't have enough good arms between them, I still had to order the "repair" kit.
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:24 PM   #3
67ChevyRedneck
Next, remove the two screws that hold the bracket onto the assembly. This is the bracket the screws into the bottom of the dash that holds the assembly in place.
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:27 PM   #4
67ChevyRedneck
Next, you need to take off the controller arm ends (I really have no idea what to call them?) I used a pair of pliers and a cloth to take them off. If you grab them by the beveled edged and gently wobble it back and forth they'll come right off.
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:31 PM   #5
67ChevyRedneck
The next part is tricky. The metal on these old units is very brittle. You need to CAREFULLY bend the tabs on the side of the face of the controller out just enough so that you can stick small screwdriver behind it to pop the face off. You only need to do one side, during reinstall you just slip in the side you didn't bend first, and them push the other side in, more on that later.
If you're not carefull you will break the tabs! Luckily I had two of these and I didn't break the second one!
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:34 PM   #6
67ChevyRedneck
You will now have 3 pieces, the chrome outer face, the plastic lens, and the metal background piece.
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:40 PM   #7
67ChevyRedneck
Next, you'll have to take the face off the the metal structure. There is one tab on each side, and two on the top. I COULD NOT get the top tabs off without breaking them. That sucked, but it was an easy fix (more on that later.) With the top tabs broken off, I pulled the face away and the side tabs slipped out of place and the face came off.
To get the face off completely, you need to slide the arms all the way to the left side of the face and there is an opening for all of the black plastic sliders to slide out of.
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:44 PM   #8
67ChevyRedneck
The last step in deconstruction is to remove the tab that keeps the arms in place. It's riveted to the top structure somehow and the only way to get it off is to break it? I have a fix for this later. Once that final piece is off, you can pull all of the arms out by lifting them off of the shaft at the back of the A/C assembly (under the tab you just removed.)
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:46 PM   #9
67ChevyRedneck
All of my arms were rusty, so I seperated the arms by removing the round washer-like clip thingy (that's a technical term!) I also needed to replace the aluminum? arms anyway with the ones from my LMC repair kit.
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:49 PM   #10
67ChevyRedneck
With the arms apart, I sanded and cleaned the rust pieces (they have to be reused.) I then sprayed them with a rust paint and let them dry for a day. Once they were dry, I painted them with some flat black model paint. I didn't remove the plastic sliders (I couldn't get them apart! ) so I kept moving their position so that I got paint on all the surfaces (I HATE rust!)
I forgot to take a pic this step, but you need to reassemble the arms exactly as they were originally (they are only supposed to go one way!) I used the new LMC arms and retainer clips they provided. Look at your retainer clips when you get them, they're only supposed to go one way, you can tell better when you see them what I mean.
*I'm sorry some of these came out blurry
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:56 PM   #11
67ChevyRedneck
I then cleaned up my housings with a wire brush. Put the new arms into the face by putting the black plastic sliders into the slots and sliding them over. MAKE SURE THEY ARE IN THE CORRECT ORDER! I used my "parts" controller as a double check.
Once you have all 3 in the face, remove the pin they all sit on, mine came out easily.
Jesse James
Project "On a Dime"
Old 06-15-2007, 02:58 PM   #12
67ChevyRedneck
Take the pin and slide it into the end of the arms.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:03 PM   #13
67ChevyRedneck
Take the new assembly, and slide the face back into place on the old unit.
If you notice in the above photos, there's an arm I left in place, typically this small arm does not break and is not included in the repair kits. You need to make sure that when you put the assembly back together that:
1: The pin will slide back into place (the one at the back of the arms)
2: The arm that was not removed has a slot in it that the upper arm has to fit into so it will work properly.
Once those things are lined up you can put the face back on and carefully bend the tabs snug again.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:06 PM   #14
67ChevyRedneck
To address the problems listed above with the broken tabs, I carefully drilled small holes and used small, course, screws to hold everything in place again.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:08 PM   #15
67ChevyRedneck
Now that the main assembly is all back together you can put the vacuum switch back in. Just make sure to line it up with the slot and screw it back on. I sprayed some silicone spray in the moving areas of mine.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:09 PM   #16
67ChevyRedneck
I wasn't too confident that my fan switch still worked, plus it looked pretty crappy, so I ordered a new one of those too. Two screws and it's back in place.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:12 PM   #17
67ChevyRedneck
I cleaned (sanded) all of the old black paint off of the backing face and repainted it with some model paint. I didn't need to paint the whole thing because I was going to use a white face overlay. If you were doing a restoration I'd used some flat black spray paint for the whole thing.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:16 PM   #18
67ChevyRedneck
I ordered a white face gauge kit from whitegauges.net from ebay. The instructions were easy to follow. Remove backing from overlay, spray soapy water solution onto back of overlay, apply overlay, use hair dryer to "shrink" overlay into place and evaporate water.
Once that was done, I needed to clean my lens. Used some paint scratch remover for car paint and a buffer wheel on my dremmel, it came out pretty nice. I had the "older" style of lens, so it was easy to remove the paint from the letters. On the newer lenses the letters are recessed into the lens (as is the paint) and is difficult to remove.
Overlay the lens onto the backing face.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:18 PM   #19
67ChevyRedneck
I cleaned my chrome face with some Mothers chrome polish and it came out pretty clean, good enough for a driver.
Put the lens assembly into the chrome face and put it back onto the front of the unit as mentioned earlier. Once in, gently tap the metal tabs so the face is on tight.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:22 PM   #20
67ChevyRedneck
I was a little miffed at the contoller thingys that came with the LMC repair kit. The stock is on the left and the "new" one is on the right. I thought they "looked" ok, but when used on an A/C unit they hit the face of the unit when they are all the way in the left side positions. Not good. So I cleaned up the old ones I had with some Mother's chrome polish. Very disappointed, however, they WILL work well with a "heater" unit because the arms stick out past the face much farther.
Jesse James
Project "On a Dime"
Old 06-15-2007, 03:24 PM   #21
67ChevyRedneck
Finally, slide the controller thingys onto the arm ends. They just push on.
All that's left is to clean up and paint the bracket and put it back on (mine is drying, so isn't done yet.)
BUT ANYWAY! Here's the completed assembly, ready for use.
Jesse James
Project "On a Dime"
Old 06-15-2007, 05:28 PM   #22
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Great write up.It looks great too.I only have one suggestion.While you are doing all of the above steps,clean the cables and lube them.I cleaned mine by clamping one end in a vise and freeing them with "Rust Buster" and soaking them in a parts washer for aweekend then dropping them ina oil drain pan with oil in it for a couple of days.They wouldn't move when I started and the levers were broken on the truck when I got it(heater only).After treating them this way I lube them with some graphite lube once a year and they are still working easily and smoothly.(it's been 6 years).
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline
Old 06-15-2007, 08:56 PM   #23
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I went with reproduction cables which moved okay before installation (when they were straight). After installation there are enough bends that they don't move like they should. Maybe I should clean up my old ones as suggested and try them...
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline
Old 06-18-2007, 08:26 AM   #24
67ChevyRedneck
I hope the levers are steel. I don't want to take this thing apart again!
I'm hoping the vintage air unit is a lot "easier" on the cable operation than the old stock units! By hand, the doors move very easy, I'm almost to where I can hook everything up.. FINALLY!
Last pic with bracket back on.
Jesse James
Project "On a Dime"
Old 07-11-2007, 01:39 PM   #25
67ChevyRedneck
I know it's been a while.... but.... installed in the truck.....
Jesse James
Project "On a Dime"
Closed Thread
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
