Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-11-2009, 12:56 AM   #1
Captainfab
60-66 Nut
Power Steering Adapter Plates
This is the power steering adapter plate that I have been making since 1993. It is of a little different design than the others on the market. With mine you don't need to drill out any threaded holes on the steering box. All four of the steering box bolts go thru the frame. Also there is no inner plate to deal with. I don't feel it is necessary for a 2 wheel drive truck. I've had this same plate on my '66 Suburban since 1993 and put just over 120,000 miles on it with no issues. When I've installed these, I stitch weld the plate to the frame for a little added strength. This isn't absolutely necessary though, since there are four bolts securing it to the frame. Please go to our website for the currect pricing and to make your purchase. https://customfab-cda.com Included is the bracket as shown and four grade 8 bolts and lock washers, installation instructions and template. To place an order post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
For an additional part to go with this adapter plate, the tube and flange, see page 6, posts #126 and #137 and post #711 on page 29
These adapter plates can also be used on the K series frames that didn't come from the factory with power steering.
Last edited by Captainfab; 06-22-2023 at 10:46 AM. Reason: shipping price increase
Old 03-11-2009, 01:20 AM   #2
LILRED66
LILRED66's Avatar
Re: Power Steering Adapter Plates
Nice setup.
LILRED66 is offline   Reply With Quote
Old 03-11-2009, 02:11 PM   #3
joe231
joe231's Avatar
Hey John,
I noticed you turned red.....I was wondering what you had up your sleeve
nice looking piece!!
CHEVY ONLY
Old 03-11-2009, 11:21 PM   #4
Captainfab
60-66 Nut
Originally Posted by LILRED66 View Post
Nice setup.
Thanks Tony.
Originally Posted by joe231 View Post
Hey John,
Been trying to get this going for a while now......more to come. Thanks Joe
Old 04-03-2009, 11:35 PM   #5
Captainfab
60-66 Nut
TTT
Old 04-15-2009, 12:13 PM   #6
Captainfab
60-66 Nut
Bump
Old 04-15-2009, 10:50 PM   #7
toms84ss
Still available? I need one.
toms84ss is offline   Reply With Quote
Old 04-15-2009, 10:53 PM   #8
joe231
joe231's Avatar
hey, you got any pics of how it installs with all 4 bolts through the frame...that has me scratching my head.....
CHEVY ONLY
Old 04-16-2009, 12:35 AM   #9
Captainfab
60-66 Nut
Yes I still have several. Let me know how you would like to make the payment....Paypal works for me.
Yes I do Joe, but I don't seem to have them on this computer. I'll post them in the morning from the shop.
Old 04-16-2009, 12:39 AM   #10
joe231
joe231's Avatar
Cool
No hurry
CHEVY ONLY
Old 04-16-2009, 12:28 PM   #11
Captainfab
60-66 Nut
Here are a few installed pics on a couple different trucks.
Old 04-18-2009, 07:48 AM   #12
duallyjams
duallyjams's Avatar
pm sent
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-18-2009, 06:21 PM   #13
Chuck78
I was planning on getting one of the CPP or REZ brackets, but then I saw yours. I know the CPP kit comes with a steel sleeve to couple the steering shaft back together after shortening it. What do you recommend using? I suppose I could weld it back together, grind flush, and then slide a piece of steel pipe over it and weld that on for extra reinforcement. Looking for better solutions than that if there are any.
Thanks Capt.!
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
Old 04-18-2009, 10:37 PM   #14
Captainfab
60-66 Nut
Thanks Capt.!
The way I do it is cut the rag joint flange off of the steering shaft and drill the ramaining shaft out of the center with a 3/4" drill. Then shorten the shaft, slide the flange back over the shaft and weld it to the shaft. This way looks a lot cleaner and is just a better way IMO.
Old 04-18-2009, 11:14 PM   #15
joe231
joe231's Avatar
that is how my kit said to do it...worked very slick...just mark a line along the length of the lower shaft and a corresponding mark on the rag joint coupler so you can get it lined back up correctly before you weld it...
CHEVY ONLY
Old 04-19-2009, 03:28 AM   #16
Chuck78
will these work the same for a 60-62??? I know one of the manufacturer's kits advertise 60-66, but don't install as good for 60-62.
Chuck in Ohio
Old 04-19-2009, 03:00 PM   #17
Captainfab
60-66 Nut
I haven't put one of these on a '60-'62, but I don't see why it wouldn't work. It's been a long time since I've looked at the frame on a '60-'62, but it seems to me like the area where the steering box is the frame is boxed. That being the case you would need some pieces of tube to go between the inner and outter frame, and some longer bolts.
Old 04-19-2009, 03:10 PM   #18
joe231
joe231's Avatar
I have more questions for you John.....
With the other kits, as you know, the front lower hole hangs below the frame...yours doesn't...what is the angle of the gear in relation to the steering column shaft? I noticed on our '66 short bed, when i used the REZ kit the front of the gear box seemed low and the column shaft didn't really line up....I assumed it was because my cab mounts were old and had allowed the cab to sag?? but maybe it is the placement of the box?
your kit obviously puts the front of the gear higher and places it at a different angle. I really like your design..i just wonder why all the others don't do it like this? I have also wondered why no one has come up with a pit-man arm that is slightly offset to make up the spacing off of the frame so you don't need to adjust your center link towards the driver's side...
sorry, you just got me thinking with this plate....i think it is innovative and thanks for sharing it with us
CHEVY ONLY
Old 04-19-2009, 10:46 PM   #19
Captainfab
60-66 Nut
With this bracket the steering column shaft and the input of the steering box are pretty much in line. One thing that has to be done when installing my bracket is you need to loosen up the column mounts both at the dash and at the firewall. Then you can raise the steering shaft to line up with the input shaft of the steering box. Then tighten the mounts back up. When I designed this bracket I had two main goals 1) keep all the bolts on the frame, and 2) keep the draglink in the original position
Yeah that would be nice if someone would tool up and make a pitman arm to compensate for the postion of the steering box, but that's probably just wishful thinking.
Thanks for the compliments Joe
Old 04-19-2009, 10:57 PM   #20
joe231
joe231's Avatar
Right On!!
CHEVY ONLY
Old 04-24-2009, 11:24 PM   #21
cheavy metal
cheavy metal's Avatar
hey captain....great stuff. for a 66 gm truck does the power steering plate use existing holes and what truck is the donor steering box out of ? do you think I could make a column from a 80 regal work in my 66?
66 red and white gmc 350ci 700r trans now a project truck will be my daily driver rat rod
66 burgundy and white gmc 283ci th350 trans gotta ton of good parts current project
old school rulez, West Coast Canadian style
cheavy metal is offline   Reply With Quote
Old 04-25-2009, 12:11 AM   #22
Captainfab
60-66 Nut
The adapter does not use existing holes, you will need to drill all 4 holes. You can use any C-series power steering box from '69-'87. Starting in around '81 or so GM switched to metris fittings for the hoses, so you'll want to be sure to get the correct punp to go with your box so you can use off the shelf hoses. You can make most any steering column work if you have the skills to modify it if needed. However it is typically simpler to use either a pickup or van column in a pickup. Thanks for inquiring......
Old 04-25-2009, 02:17 AM   #23
cheavy metal
thanks for the response. hear ya on the column. I guess I'm hoping someones going to say hell it'll bolt right in. so if a guy grabs one of your ps adapter plates how do you know where to locate it?
Old 04-25-2009, 10:43 PM   #24
Captainfab
60-66 Nut
I don't have the installation instructions complete just yet, but I will provide you all the necessary measurements and pictures to get the job done. Plus I'm always available to answer any questions you may have. I won't sell my produsts to anyone one and just say "You're on your own" I want to make sure you're happy with your purchase.
Old 04-30-2009, 06:02 PM   #25
mikes64fleetside
thanks for the information, that makes a whole lot more sense, looks like it will save a lot of time
mikes64fleetside is offline   Reply With Quote
