Old 08-26-2009, 02:34 AM   #1
Hillbilly Deluxe 65
Wheelin' and Dealin'
Hillbilly Deluxe 65's Avatar
1965 biggest rear tire in stock wheel tubs
hey guys, i got a flat tire the other day and I wanna get some wider rear tires for some better traction, i have P235/75 R15's now i have heard ten inches is the widest size but what offset rim is that on
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside
Porterbuilt Extreme front and rear
12bolt w/ eaton tru-trac 4:11 gears
1BADD65
my build thread:
http://67-72chevytrucks.com/vboard/s...=1#post2601700
Hillbilly Deluxe 65 is offline   Reply With Quote
Old 08-26-2009, 06:22 PM   #2
astrochimp
Re: 1965 biggest rear tire in stock wheel tubs
Mine has 295/ 50 /15 at stock height.
Looks like the right rear will rub slightly on the inside tub (clean spot on tub)
No idea on rim offset, but it looks pretty equal on each side. I think it a 10" wide rim, will know when I find steels and get these off.
photo here-
http://s185.photobucket.com/albums/x...t=DSCN0805.jpg
David
astrochimp is offline   Reply With Quote
Old 08-26-2009, 07:46 PM   #3
shrunken66stroker
shrunken66stroker's Avatar
I have a 9" wide rim with 255 60 17's with a 0 offset and they fit perfectly. The tire is about 10 1/2" wide total and it is dead center with a 0 offset. The measurements I have from the inside of the rear fender to the start of the wood in the bed is exactly 13" on mine.
shrunken66stroker is offline   Reply With Quote
tire size, tires, wheels, widths
