Old 02-11-2014, 07:54 PM   #1
Theoriginalsilverado
Talking Chevy High Performance 350- Fit or no fit?
Hi guys, I'd like you to check out the link I have posted below. I probably never will purchase another motor for my old 1975 C20, but I would certainly love to. One of the best replacements I've come across so far is straight from Chevy, and for a good price.
It's a 350 with 290 HP. All the Dyno specs are listed, and it seems to be a really good motor.
My question, is will it fit our trucks without any major modifications? Specifically a 1975 C20 with a stock 350?
You can view the motor at THIS LINK--> http://www.chevrolet.com/performance...-hp.html#parts
If It runs like a Chevy, it probably is!
Theoriginalsilverado is offline   Reply With Quote
Old 02-11-2014, 07:57 PM   #2
Re: Chevy High Performance 350- Fit or no fit?
Quite an attractive motor if you ask me...
Old 02-11-2014, 08:14 PM   #3
TheBlueBomber
TheBlueBomber's Avatar
Yea it is. So much better than ls motors imo...
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 02-11-2014, 08:26 PM   #4
80SPORT
80SPORT's Avatar
We have put several in pre 86 pickups...drops right in.
It is the same motor as the base 260hp goodwrench/targetmaster but with the L82 cam and valve springs
Works well and sounds nice with duals
And is GM warranteed!
80SPORT is offline   Reply With Quote
Old 02-11-2014, 08:46 PM   #5
cory d
cory d's Avatar
hmmmmm, "forget the rebuild". you could build a more powerful 350 for less that half cost. and not have 8:1 CR
cory d is offline   Reply With Quote
Old 02-12-2014, 07:53 AM   #6
Jake Wade
Jake Wade's Avatar
More like 7.8-7.9:1. One would be better off with the 260HP version with that paltry CR.
Jake Wade is offline   Reply With Quote
Old 02-12-2014, 10:16 AM   #7
rs74
rs74's Avatar
If you are going to buy an engine then I would check out Summitracing.com. Not sure what the price is that you were quoted from Chevy but if it is what is listed on your link then Summit can beat that price.
Save $400
http://www.summitracing.com/parts/na...make/chevrolet
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-12-2014, 10:27 AM   #8
TheBlueBomber
I didn't look at the price before. 3k and you could build it yourself and get more power. Just wouldn't have a warranty.
Austin
Old 02-12-2014, 11:13 AM   #9
80SPORT
80SPORT's Avatar
In a street truck with todays fuel the 8:1 compression makes for a reliable engine;We have used both the 290hp and 260hp versions;for the price difference I prefer the 290hp...especially in a short box sport truck.And it sounds better.Hard to beat the 2 year GM backed warrantee and ALL brand new parts.
Old 02-12-2014, 12:47 PM   #10
MikeB
MikeB's Avatar
I agree 100%. Cylinder pressure with the bigger cam is very low. And that means low torque and not-so-great throttle response, certainly under 2500 RPM.
I don't know what GMPP was thinking, unless they wanted a lopey idle (misfires) and didn't care about loss of torque. At least they could have selected a cam with a tighter LSA, or cylinder heads with smaller combustion chambers. I think CompCam's #12-306-4 at 206/212 on a 108 LSA would work much better than the larger GM cam. You can also get it on a 110 LSA as #12-308-4.
On another note, I have had a couple 9.0:1 to 9.3:1 engines with iron heads, Neither one needed premium gas except on very hot days with coolant temp at 200-210. Of course, quench height on both was in the .040"-.045" range. On the GM crate engines it's .060"-.070", which is more prone to detonation.
Mike
1969 C10 LWB -- bought in 1989
1982 C10 SWB -- owned 2013-2020
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 21 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
350, chevy motor, dyno, replacement motor
Thread Tools
Display Modes
Copyright ©2000 - 2022, vBulletin Solutions Inc.
