11-25-2014, 05:09 PM | #1 |
cummins conversion info needed
I am thinking of a 6bt conversion I want to use my sm465 and my np205 and a gear venders od that I have. Does anyone know where I can get a adapter to mate the sm465 to the cummins? And can I use my current braking and power stearing ? I see a lot of guys going with the hydroboost set ups. And I want to add vintage air down the road. Do I still order a kit for 67-72 trucks knowin its gonna have a cummins in it. I know I got to box the whole frame for the cummins, atleat a 12in clutch. I really don't want to by a new trans n transfer case.
'72 chevy k20 '06 H-D Springer softail http://www.bluemooncruisers.com/ http://www.enginecycle.com/ ~Eric |
11-26-2014, 02:42 PM | #2 | |
Vintage 4x4s
Re: cummins conversion info needed
There are probably aftermarket adapters but I'm not sure how much they cost. Have you looked at advance adapters? I'm no expert. Many guys will tell you to go nv4500 but the problem with them is they need 5th gear fixed, are expensive, and you need a 50 ton press to rebuild them or have to pay someone to rebuild them. They do have a better shift feel though. I like the G360 personally based on what I've read and seen since they are easy and cheap to rebuild and seem to last if you put an extra quart in to keep them cool. I've read the 10 spline on your NP205 may be the weak link, if you have turned up the cummins or are using 4x4 much. May want a higher spline count if so, and at that point, you may as well just get a g360/np205 combo.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 11-26-2014 at 02:52 PM. |
11-26-2014, 04:19 PM | #3 |
6>8 Plugless........
An adapter to use a chevy bell housing is $795 give or take. How much torque will that gear vendors OD take? I agree with Jud, that tcase probably won't live long with the small input. For the money you'll have getting the SM465 and gm NP205 behind it, I would just use a NV4500 and a 29 spline dodge NP205. Or find a round pattern 32 spline GM 205 and swap inputs. Either way you're spending money so really the decision is yours. The NV4500 is a great trans and it isn't hard to repair the 5th gear problem. I've rebuilt them without a 50 ton press. Jud, are you thinking of the NV5600? It requires a 50ton press and I haven't rebuilt one due to that. NV5600's are just plain expensive. But I'd still rather have a NV4500 or a NV5600 before I'd use a SM465 behind a cummins. If you plan to have a real mild truck, boxing the frame is not necessary.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-27-2014, 12:52 PM | #4 |
Gear venders says there units are rated for 1500 plus of torque. yea i know about the shafts for the 456/205. i was pricing nv4500 i found there ranging from 2k to 3k. 2k for just the trans and 3k for the kit plus the trans. I think it would be cheaper to replace the shafts and find an adapter. I have 2 sm465 and 2 nop205s i don't think i need to buy anther trans or transfer case i gladly trade someone. As for as boxing the frame what needs boxed? I read somewhere that you can use a bh off of a nv4500 to use with that sm465 to an 6bt. i just don't remember where i readed it and what need to be done with it as in mods
11-27-2014, 06:08 PM | #5 |
I'm not sure from reading this but do you already have the Cummins?
If not you could get a complete truck with the 12valve and get the transmission and transfer case and most everything else needed for the swap for not much more than 3 or 4k up here anyway. Would just be completely rotten.
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 |
11-28-2014, 03:55 PM | #6 | |
Is your gear vendors OD the one that goes on the front of the trans, or after the tcase?
11-29-2014, 09:32 AM | #7 |
gear venders unit goes behind the transfer case. thought of going the route of buyin a complete truck 92-97 ram but everyone around here want 8-12k for them. MY buddy has a 97 6bt laying around he had it for few yrs tryin to talk him out of hes into those jeep Cherokee n he need $$$ so thought about waving a few hundred in front of him n see if he bites.
11-30-2014, 11:22 AM | #8 |
$8-12k is nuts isn't it? My brother's 97 2500 4x4 5 speed with 220k books for $10500. Crazy. However, if you keep a keen eye out, they pop up a lot for under $4k. The gear vendor you have would work fine. So if you did an input swap on the 465 and got an adapter plate, you may be able to be in business. Just keep your engine near stock.
11-30-2014, 04:47 PM | #9 | ||
Vintage 4x4s
Just get a rusty 1st gen with getrag and the right np205 if you're going to buy a whole truck and don't want to spend more than 4k Ryan, 4k for a 2nd gen 4x4? I've been looking for 2 years around here and haven't found one yet, just 1st gens.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
11-30-2014, 05:15 PM | #10 |
Have you tried looking for a 6bt from a school bus? I know some Blue Birds used to have the 6bts. It will most likely not have a transmission that you can use but you might be able to save enough on the initial purchase of the bus plus scrapping the rest? School busses come up cheap on auctions on all the time.
