Old 01-29-2015, 12:22 PM   #1
1FUN64
1FUN64's Avatar
Ls oil pans
Lurking here alot for information, working on a 5.3 swap into my 64. This is a great source for assistance, inspiration and ideas. Went through the oil pan search and came across a good website that shows good images of these pans. GMpartsdirect.com, type in an oil pan part number in the search and the majority of them have good images with dimensions. It also has the parts associated with it, windage tray, pickup tube, etc.. Also shows application if you want to visit your local salvage yard or search on ebay. I attached some documents showing a few hopefully it comes out alright.
I'm sure there are many other part numbers out there, these are the ones i was looking at, feel free to throw more part numbers at this.
Thanks to all those sharing their knowledge on here it really helps.
Attachments did not work, tried to make it easy with pictures.
gmpartsdirect.com and search these numbers:
http://www.gmpartsdirect.com/
12628771
12631828
12640748
12581209 Front sump, not much use to us.
19212593 Go to Summit for an image with dimensions for this one.
http://www.summitracing.com/parts/nal-19212593
302-1 and 302-2 Holley swap pans, Holley.com for dimensions.
https://www.holley.com/products/acce...ns/parts/302-1
https://www.holley.com/products/acce...ns/parts/302-2
LS1Tech has a great thread also.
http://ls1tech.com/forums/conversion...-oil-pans.html
Kent
DRIVE IT HARD, DRIVE IT OFTEN!
Short video of Black Betty & a friends 48 Panhead done by my kid.
https://www.youtube.com/watch?v=8DlAdfwDQa8
1FUN64 is offline   Reply With Quote
Old 01-29-2015, 12:48 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Ls oil pans
If you are real low, any pan that is level with the front cross member is what you need. I have heard CTS-V, H2 Hummer and the hot rod oil pans work well. The summit one you show is the one I wanted to put on my 65 but am too lazy to pull the motor. my truck isnt very low, 4/5 drop so a stock pan works for me.
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-29-2015, 01:11 PM   #3
1FUN64
1FUN64's Avatar
Re: Ls oil pans
Ended up going with the F body pan, 12628771. My truck is pretty low so I wanted it tucked up as much as I could get. Still doing chassis work so i have not even set it in yet.
Kent
Old 01-29-2015, 02:21 PM   #4
BigMike608
BigMike608's Avatar
Re: Ls oil pans
this is the one I used
http://www.summitracing.com/parts/hly-302-1
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop
BigMike608 is offline   Reply With Quote
Old 01-29-2015, 10:39 PM   #5
H20cooled
Re: Ls oil pans
I have the CTSV pan in my 68, it does not hang below the front crossmember. I got it off of ebay for a pretty good price it was pulled off a new car.
H20cooled is offline   Reply With Quote
Old 01-30-2015, 04:39 PM   #6
1FUN64
1FUN64's Avatar
Re: Ls oil pans
Wanted to add some images, we will see how it works.
12628771 F body
Kent
Old 01-30-2015, 04:42 PM   #7
1FUN64
1FUN64's Avatar
Re: Ls oil pans
Had to do multiple post to get images and text correct.
12631828 Cadillac CTS-V
Kent
Old 01-30-2015, 04:43 PM   #8
1FUN64
1FUN64's Avatar
Re: Ls oil pans
12640748 LS3 Camaro / G8
Kent
Old 02-01-2015, 01:06 AM   #9
Willie Makeit
Willie Makeit's Avatar
Re: Ls oil pans
cts-v pan here on a 5.3 in a '67 on air bags. no troubles as the cross member hangs lower than the pan by about 3/4"
Willie Makeit is offline   Reply With Quote
Old 02-01-2015, 11:56 AM   #10
Tilt
Re: Ls oil pans
Anyone with a CTS-V pan on an 80's model? Just wondering where the bottom sits in relation to the cross member.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
