Old 08-12-2016, 12:28 AM   #26
lime1982
Re: 1984 c10 barn find
Awesome job on the c notch . I never even thought of doing that I was going to order a kit but that looks like it worked out great. Thanks for the idea!
lime1982 is offline   Reply With Quote
Old 08-12-2016, 07:06 AM   #27
95chev-w/t-guy
95chev-w/t-guy's Avatar
From everything I've researched, and people I've talked to, this is stronger than any kit you can buy if you do it right. Good luck!
1984 c10 - my forever truck
1991 GMC R2500 6.2 Diesel
1995 GMC K2500 LQ4 swap coming soon
2002 2500hd cclb LQ4/NV4500 2wd - parted out
1998 c1500 - sold for parts
1995 c1500 - sold to my brother, then sold again but still going
95chev-w/t-guy is offline   Reply With Quote
Old 08-12-2016, 07:08 AM   #28
95chev-w/t-guy
Originally Posted by LT7A View Post
Cool that you were able to save your Grandpa's truck and that it's running as a reliable DD for you. Good work on the C notches. Wish I could weld.
Thanks! I have to admit though, my brother did the welding, he's much better at it!
Old 08-12-2016, 07:09 AM   #29
95chev-w/t-guy
Originally Posted by rusty76 View Post
Looking great.
Thanks!
Old 08-02-2017, 12:30 PM   #30
95chev-w/t-guy
Haven't been here for awhile but I've got quite a bit done to the truck so I guess I'll give a quick update. Last summer this truck was my daily driver. It worked great but by the fall it was leaking oil badly. I thought about rebuilding the engine, but I got a better deal when a now good friend of mine gave me a low milage and tight 305 and helped me put it in the truck at his place. I can't remember why, but for some reason we ended up using one car manifold and one truck manifold, the engine was out of a 73 caprice I think. Anyway I upgraded to headers and duals with no crossover and put some thrush turbo mufflers and turn downs on it. Soon I'll be putting air shocks on the back, as well as a new gas tank and some general maintenance to get it back on the road. However I'm working on long shifts away from home this summer, and it's proving more and more difficult to get things done during the short periods I am home. I'll have pictures to come of the truck soon. In the meantime, I figured I'd post my other 2 non chevy projects just for fun. My 1956 pontiac star chief catalina and my 1975 vw van.
Old 08-02-2017, 06:12 PM   #31
rusty76
rusty76's Avatar
Digging the bus and Pontiac.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-11-2017, 06:03 PM   #32
95chev-w/t-guy
As promised, some pics of the new exhaust setup. I still have to change some of my plug wires for clearance and figure out what to do with my power steering pump bracket. I'm thinking of making a spacer for between the header and the backside of the bracket and using one of the factory manifold studs as shown. Anyone else have a solution?
Old 08-11-2017, 06:04 PM   #33
95chev-w/t-guy
A better view of the P/S pump bracket
Old 08-11-2017, 06:14 PM   #34
95chev-w/t-guy
I forgot to mention I got a more suitable tailgate too!
instead of I think it looks a lot better, but I've always had a soft spot for tailgates that don't match the colour.
Old 02-05-2019, 10:36 PM   #35
95chev-w/t-guy
Hey, I haven't posted on here for awhile, but stay tuned for a drivetrain swap. I plan on doing the actual swap next winter/spring, and I'll be gathering up parts and ideas as it gets closer to that time. First, an update. I haven't done much other than drive it since my last post. I found a stock radio with a cassette player and put that in, fixed a rotten rubber gas line, and I still have a leaking axle seal (I'm planning on swapping rear ends so I never bothered fixing it yet).
For the drivetrain swap I found a 2002 2500hd 2wd cclb, with a 6.0l and nv4500 5 speed. I'll be swapping that in during next winter spring, but I'd like some advice from people that have done similar swaps on the best places to get parts and what stock parts I can reuse (the computer for example, can the stock one just be flashed and reused?). I'll need mounts, wiring, headers, driveshaft, etc. Any and all advice would be appreciated. Here's a few pics of what will be the donor truck. Its currently my daily driver, that's why I'm waiting until next winter to start the swap. It used to be a DOT truck, and the interior is VERY dirty, but it works great and has lots of power, and it loves 3rd gear lol. It should work great in my c10!
Old 02-15-2019, 09:53 AM   #36
95chev-w/t-guy
So here's my first round of questions. As I said I'm daily driving this truck so I can't really tear anything apart to get the answers myself, but some of you on here must know.
1. Did the make a clutch pedal assembly for c10's that used a slave cylinder setup, or were they all mechanical linkage?
2. Any recommendations for a speedometer setup? I've seen boxes that use the electrical output from the newer trans and have an electric motor that drives the speedo cable for the old speedometer, is this the best way to go?
3. Anyone know how many splines the output is on a 2wd 2002 Silverado HD with nv4500? Is there any chance I can reuse the driveshaft in my c10 with some modification?
There's going to be more questions coming. Ideally I'd like to have as many parts ready as I can before the swap and have as much info going into this as I can. Also, aside from some accessory noise, the 6.0l and nv4500 are working great while I'm daily driving the 2500hd!
Old 02-15-2019, 01:34 PM   #37
dmack91
dmack91's Avatar
Regarding the clutch, my 83 K20 has a hydraulic clutch from the factory.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 02-15-2019, 07:23 PM   #38
95chev-w/t-guy
That's what I was hoping for, thanks. I've only ever seen the other kind.
Old 03-17-2019, 08:22 PM   #39
95chev-w/t-guy
On Thursday I learned a lesson about safety the hard way. I was working under my 3/4 ton truck when it fell off the jacks and pinned me under the frame. The frame wasn't touching the ground, the full weight of that corner of the truck was on me. The neighbors babysitter heard me yelling and got my fiance, Emily, out of the house. She jacked it up enough for me to get out. Things could've been alot worse, and I'm very very lucky to have walked away from that. I've got lots of pulled muscles and bruises, and some pinched nerves, but nothing permanent or broken. Keep in mind everyone, you never think it'll happen to you, but it can. Always take a minute to think about what you're doing when you get under a car. We all do it so often, we tend to forget just how dangerous it really is. Have fun, and be safe!
Old 03-18-2019, 08:56 PM   #40
dmack91
dmack91's Avatar
Glad you made it out with relatively minor injuries.
Old 03-18-2019, 09:12 PM   #41
TKCR
TKCR's Avatar
That could have ended badly, for sure. There was a guy, just this last week here locally, that didn’t make it. Glad to hear your alright
Old 07-16-2020, 11:20 PM   #42
95chev-w/t-guy
I haven't posted much on here since my accident with the truck falling on me, because honestly I lost my ambition to work on anything for a few months. Then I decided to get married, and started working on restoring my fiance's VW, since my c10 is still on the road with the sbc in it and works fine as is. I'm glad I did that, because it slowly got me back into working on cars again. With her car being almost back to life, I'm now getting back into working on the C10, and even just did a small roadtrip in it. I've gathered up a few parts and think I've figured out what I want to buy for aftermarket parts when I've saved up enough. I'll get back to posting updates as I go, but up until now nothing has really changed apart from regular maintenance. Here's some recent pics, one is from a day a few weeks ago I hauled some gravel (I was dragging the trailer hitch on my way home ).
Old 07-17-2020, 11:35 PM   #43
hatzie
Moderator
hatzie's Avatar
I just read this.
You're a lucky lucky boy.
Two neighbors died from that kind of accident when I was a kid. One of them was a friend's teenage brother. We found him under the Charger he was working on and he was obviously gone. The other guy was old enough to know better... working on a lifted dump bed without cribbing that fell on him. That kinda stuff stays with you.
I'm exceedingly careful around stuff that's lifted off the tires and stuff that could fall on me. Jack stands, chocks, cribbing, etc.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-30-2021, 12:27 PM   #44
Andrij
Andrij's Avatar
I was told when taking off a tire, put the rim under the frame.
Also thanks for your post about the spindle clearance. Have a great day!
Andrij is offline   Reply With Quote
6 liter, barn find, c10, ls swap, squarebody
Thread Tools
Display Modes
