Old 04-08-2016, 08:04 AM   #1
nicoson12
1972 proyect... i need help with 10" rims
Hello! i am new here, i'm from Chile and i have been reading a lot on this forum, i have a big question about the rims for my 72'... while my truck is in painting i bought 4 rims 15x10" US WHEELS SUPER SPOKE, so i want to put them all around, the problem is that here i see that most of the trucks use 8" in front and 10" in the back......
will i have issues with the 10" in the front?
Can i put disc brakes in the front with a 10"?
i am also thinking in 275/60R15 Tires all around....
Thanks guys!
nicoson12 is offline   Reply With Quote
Old 04-08-2016, 09:28 AM   #2
DBK81
DBK81's Avatar
Re: 1972 proyect... i need help with 10" rims
It will all be dependant on back spacing of front rims. You won't have issues with factory size disc brakes fitting inside a 15" rim. 275 up front is a pretty large tire. Biggest I've seen is 255/60/15, but that doesn't mean it can't be done.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 04-08-2016, 10:06 AM   #3
mgore68
mgore68's Avatar
My truck has been lowered 4" and has 10s all the way around. I am not sure about the back spacing but when I bought it, it had 295 50 16 on it. I am now running a 235 50 16. The 295 would rub a little if I hit a big hole or something.
mgore68 is offline   Reply With Quote
Old 04-08-2016, 10:06 AM   #4
nicoson12
Thanks friend!... i have read that for 10" rims... 245/70R15 on the front and 295/60R15 on the back should be fine too.
Old 04-08-2016, 10:10 AM   #5
nicoson12
Your truck looks great!, thanks.
Old 04-08-2016, 10:37 AM   #6
67chevy_hotrod
67chevy_hotrod's Avatar
I had 275's up front and it's dumb lots of stress on power steering when your not moving fast or it's impossible to move with no power steering( longhorn on 31" mudders no p/s) Gotta love it. 10's will be pretty wide up front but clearance shouldn't be an issue with stockish components..
1967 Chevy CST 10 "Susan"
1969 Chevy C/20 Longhorn "Gloria"
1972 Chevy Cheyenne Super 10 "Sherry"
67chevy_hotrod is offline   Reply With Quote
Old 04-09-2016, 07:04 AM   #7
Boog
laying low
Boog's Avatar
Thanks guys!
Chile huh? Welcome aboard. Further evidence of Chevy truck love around the world. You asked if you could put disc brakes on the front. If your 72 is a US produced truck it should already have front disc brakes on it. If built elsewhere I have no idea. The 10" wheels should fit all around with no clearance issue with the stock ride height. If it's going to be lowered much you could have some issue. 275/60/15 tires are beefy but there is a lot of room in those fenders. You should probably carefully mount one wheel on the truck without a tire and stand back to look. That way you can visualize just how it will sit in the fenders considering the wheel back space and all.
There are lots of threads here pertaining suspension lowering, wheel and tire fitment and combinations. Use the search button and look at plenty.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
10", 15x10, disc brake conversion, rims, wheel
Thread Tools
Display Modes
Copyright ©2000 - 2022, vBulletin Solutions Inc.
