08-30-2016, 05:36 PM | #1 |
large 40 gal Aero tank question
I need to drop my tank. It is the bolt through the floor and tank style with long carriage bolt from the top and I am assuming the flat washer on the underside is the nut (center fits 3/8 drive). I know the nut will not come loose today but may with a few days of wd-40. If not anyone have luck with grinding the head off the bolts and driving them from the top and have the nut come off the tank that way? Then I would just use threaded rod to re install.
08-30-2016, 10:20 PM | #2 |
Re: large 40 gal Aero tank question
WD-40 isn't very good at penetrating rust. Try PB Blaster, or you can make your own from a 50/50 mix of acetone and ATF. Supposedly that's the best rust penetrant there is.
08-30-2016, 10:36 PM | #3 | |
09-01-2016, 01:46 PM | #4 |
I had to grind the heads off from the top. I tried soaking for weeks. Stripped the 3/8 drive hole and ended up giving it to another board member and he drilled them off from the bottom.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
09-01-2016, 05:23 PM | #5 |
Seems like a pattern. I ground off the heads and 3 dropped out fine. The last one is being a real bear.
09-01-2016, 07:44 PM | #6 |
Don't know how long mine had been in the truck, maybe 20 yrs or better.I am going to use it again, got use to the capacity for trips. Good luck.
09-02-2016, 05:54 AM | #7 |
I had one come out easy. The other three I had to grind the heads off. Tank came out easy enough. I was never able to remove the bolt remnants from the sleeves in the tank.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
03-04-2018, 08:15 PM | #8 |
Swap to strap? Anyone done that? What strap?
