06-25-2017, 07:39 PM | #1 |
Low Buck Holes-Free Headliner
I made this out of 1/2" foam wall insulation from Lowe's and 1 sq yd.of vinyl fabric from Walmart. Easy project. Simply cut the board to fit the roof inset and spray it with hi-tack. Then spray the fabric. Next, gently set fabric on board (glue to the white side because its tougher and you will need to lift and smooth the fabric. ) Then wrap it around the other side and glue the straights and tailor the corners. Next glue the corners and apply industrial strength Velcro stickies to the board spacing them so as to avoid the ribs in the roof panel. Then, go in the cab and stick it to the roof. Add more Velcro stickies as needed by peeling it down and reaching your arm in there. Then go for a drive and enjoy your new headliner.
06-25-2017, 07:46 PM | #2 |
Re: Low Buck Holes-Free Headliner
That is just too cleaver!
Thanks for sharing, I bet that cuts down on the heat from the roof. |
06-25-2017, 08:12 PM | #3 |
Looks Good, Thanks
06-25-2017, 08:33 PM | #4 |
cool idea thanks
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
06-25-2017, 11:09 PM | #5 |
Thanks guys, I sure hope it helps keep the roof cooler. It's been a scorcher around here. Btw this is the glue I used. Sticky stuff. I had to wipe my fingers with a gas rag just to keep things from sticking to them.
06-26-2017, 06:34 AM | #6 |
looks good well done
06-26-2017, 04:10 PM | #7 |
i like it, is it any quiter ?
what fabric did you use? |
06-26-2017, 05:52 PM | #8 |
Nice Dave! I love tricks and tips like this. I have been know to a few!
06-26-2017, 08:24 PM | #9 |
The fabric is a vinyl faced type with a synthetic material on the backside. As to if it's quieter... it's hard to say because the cab is pretty well sound deadened already. Although, a quick check with the temp laser did show the headliner to be 4 to 5 degrees cooler than the surrounding metal while cruising with the a/c on.
06-26-2017, 08:56 PM | #10 |
Nice idea. Looks good.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
06-26-2017, 09:59 PM | #11 |
Great information & write up! Thanks for the information.
06-27-2017, 04:48 PM | #12 |
Thanks for the tip I need to do something. It was 99 in Burbank CA this Sunday and I drove the truck around a little. I was not able to touch the ceiling of the cab because it was too hot.
