Old 09-23-2020, 12:41 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
Question about axle seal surface problem
This is on a Dana 60. I've replaced this seal before and eventually the shoes get soaked in gear lube after a few thousand miles, maybe sooner and I don't notice it. There is a lip on the very edge of the surface and a couple very shallow grooves near the back. Actually the middle of the surface feels pretty good. The new seal fits snugly onto the surface. What can I do?? I use this truck to haul heavy loads occasionally and I need the back brakes to function perfectly. Thanks, -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 09-23-2020, 12:43 PM   #2
WorkinLonghorn
Re: Question about axle seal surface problem
The result:
Old 09-23-2020, 01:17 PM   #3
HO455
HO455's Avatar
That's a job for a Speedi Sleeve or Redi Sleeve depending on which brand you get. I used them lots of times at work. Here is one video but there are lots more out there.
I've usually cooled the shaft and heated the sleeve by setting it in the sun to make installation easy.
https://youtu.be/5XIjYuhxKsw
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 09-24-2020, 08:28 PM   #4
WorkinLonghorn
Thanks, I'll check it out if this latest seal doesn't.
I really don't see how one of these would accept the stock seal though. The diameter will be bigger and the seal will not be running as designed. Also, I don't have an accurate micrometer and anyway, would they have that EXACT size? On the video the guy mentions "filing" the surface. Really? Filing a seal surface? How would you keep it perfectly round and at the correct depth. This might be beyond my backyard mechanical skills. -BA
Old 09-24-2020, 10:44 PM   #5
Bimus
Do a search for Speedi sleeve for Dana 60 wheel seal . may be this will help .
Bimus is offline   Reply With Quote
Old 09-25-2020, 10:44 AM   #6
HO455
HO455's Avatar
If you look at their demonstration shaft you can see that it has lots of scarring on it. You would want to file any high spots off of that shaft surface. In your case you have a different kind of damage that won't require filing. I would use some 380 grit or so emory cloth on it and then coat the surface with some red Loctite before installing.
The sleeve is very thin stainless steel that I believe it is about .010 thick. Most seals used in vehicles won't have a problem with that much over size. I have used them to fix several harmonic balancers that were grooved and leaking. Similar to the repair you need.
You can also repair the surface where a bearing has seized and gauled the shaft. In those cases you would file the surface as best as possible and installed the sleeve before replacing the bearing. This is an emergency type repair. Although when I had the rear end on my Burban gone through they found one axle that had one installed under the bearing. I replaced that axle
These type of sleeves have been around for many decades are are used mostly in industrial applications they come in literally thousands of sizes from just under 1/2" to I believe 8 inches. So measuring with a micrometer would be important but the automotive parts industry now has these listed by application so you shouldn't have to have a micrometer to get the correct size.
https://www.napaonline.com/en/search...onEnabled=true
Old 09-28-2020, 12:02 AM   #7
WorkinLonghorn
Thanks HO455. What I did was install the seal slightly indented so that hopefully the seal will ride a few thousandths off of where it didn't seal before. There was slight friction against the bearing but so far so good.
After reading links found by following Bimus's suggestion and your info, I will definitely go that route if it still leaks. Thanks again. -BA
Old 09-28-2020, 09:13 PM   #8
HO455
HO455's Avatar
You are welcome and best of luck.
Old 09-30-2020, 07:12 PM   #9
kwmech
Speedi sleeve and get rid of that crap CR seal and get a National or Timken 51098 if memory serves. ALSO !! check the vent on the axle tube and make sure it is not plugged up
Thread Tools
Display Modes
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
