Old 07-14-2021, 03:14 PM   #1
brian1115
Fuse Block RUN and Crank Source?
I have my LS PCM and wiring harness mounted inside the cab of my truck. I see many videos showing the distributor wire is hooked up to the pink switched ignition of the LS harness. I get that
However being located inside of the cab can I tie the switch 12V+ pink wire from my Ls harness into one of the unused IGN ports on the stock truck fuse block?
Basically what I'm asking is does that pink distributor wire from the engine bay branch off to the IGN terminals on the inside (cab side) of the fuse block instead of connecting it to the wire located in the engine bay.
1986 Chevy Fleetside Wrangler (Canadian Only)
brian1115 is offline   Reply With Quote
Old 07-19-2021, 10:36 AM   #2
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Fuse Block RUN and Crank Source?
brian,
not sure if you know about brandons' web page so I will post a link. it is a wealth of info for swaps. for your question though, I am not sure about the pink wire to fuse box? (i don't think so). I do know that the "open slots" on the fuse box are open for the factory options ordered above the "basic" truck functions. IE: custom deluxe compared to silverado.... not 100% on that though.
link: https://www.lt1swap.com
rodstored-72 is offline   Reply With Quote
Old 07-19-2021, 11:37 AM   #3
brian1115
I went on PSI's sit and located under the FAQ it says to hook up the keyed hot to any open fuse block location marked "IGN" so that is what I did.
That is only if you are mounting inside the cab. Should work fine, I will know when I fire it up.
Old 07-21-2021, 10:34 AM   #4
rodstored-72
chevy truck fan
brian,
good luck let us know how it goes.. I bet it will work though..
Old 07-21-2021, 01:53 PM   #5
brian1115
Originally Posted by rodstored-72 View Post
brian,
I will thanks
Old 07-21-2021, 08:34 PM   #6
TrybalRage
It would probably work, but I instead added a small fuse block just for constant 12v+ needs when I swapped.
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
TrybalRage is offline   Reply With Quote
Old 07-22-2021, 07:52 AM   #7
brian1115
Yes I also made a fuse block panel for dedicated keyed hot for accessories I'm adding to the truck
