![]() Join Date: Oct 2006
1968 Suburban 4X4 front axle swap ?
Looking to swap out closed kunckle front axle with drums to open knuckle with disk. Does anybody know what year axles will bolt in place on stock 1968 4X4 suburban.
Posted via Mobile Device |
Re: 1968 Suburban 4X4 front axle swap ?
So I have a 70' K30 4x4 burb and I used a 85' K20 front axle since it had front disc brakes. And it fit with no issues.
Thanks!!!! Appreciated
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
Why are you looking to swap to disks? Not happy with the drums up front? I tried to locate an front axle with disks and had a rough time finding one here in NJ.
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Open knuckle have a tighter turning radius and finding parts for newer disk axle will be way easier than dealing with the leaks from a old close knuckle system.
I’ll keep original axle to go with rig when I sell it but coming down big mountain roads drums up front suck with getting to hot and fade vs disk.
![]() Join Date: Mar 2008
That's a cool Burb...
NHRA Super Street 469C It only runs 10.90 at 156 mph |
![]() Join Date: Mar 2003
Any chevy straight axle up to 86 -- blazer and suburban will go up to up to 91
I just put discs on my closed knuckle 44. To me it was much easier than swapping axels. JMO.
60sIron where did you find a disk brake conversion for a close knuckle 44 axle? Thanks in advance. I’m still looking for a complete front and maybe front and rear if the have lower gearing than the 4.11 like 3.42 or something in that range.
Unfortunately there is no kit. I had a Dana 44 out of a 72 with disc breaks. I swapped out everything from the knuckles out. The only thing that isn’t a direct fit is the original axles from the closed knuckle need to be turned down slightly to fit the new bearings. It was easy for me as I have a friend with a lathe. You also must change the Master. If you search this sight you’ll find more information. That’s where I found it. Just for your information the breaks for a 14 bolt can be installed on an HO. Backing plates on out. Good Luck.
![]() Join Date: Jun 2014
Are those Alcans on there ??
No Americans. Unfortunately they were 16.5’s. I needed tires and the selection for that size is extremely limited. It now has 16” steelies with hub caps. When it’s time for tires again it will be 17” US Mag slots. I love the look.
#13 |
Junior Member
![]() Join Date: Mar 2015
Love the Burb. I was really close to picking up one very similar to this a few years ago in Tacoma WA area.
#14 |
The steel rims on the 68 Burb are off a old blazer 15 X 8’s
#15 |
Picked up a front axle out of 1990 1500 suburban for $250 that bolts right in. 3.73 gear ratio matches existing and pinion and ring gears are in excellent condition. Lucked out I’ll
Post pics of the swap on my Burb thread. Thanks for the reply’s get me going in the right direction for the swap.
#16 |
![]() Join Date: Feb 2002
Great score.
I have a '67 K/10 Suburban I want to resurrect. I put it up in '98 after an engine fire. I intend on a '69 or later Dana 44 that will give me P/S + P/B. An earlier attempt at putting a P/S gearbox off a '69 C/10 was a goatf#$%. Totally screwed up the turning radius and steering geometry. Went back to the cracked-case manual gearbox and it was still AFU. Then there's the brakes -- can you say Fred Flintstone? It was almost a case of Select Alternate Target for collision. Disc brakes will be a much needed improvement.
Thread Tools | |
Display Modes | |
