12-10-2021, 06:43 PM | #1 |
Tilt steering column for Automatic trans.
Tilt steering column for 67-72 Chevy truck with automatic transmission. Column was originally in a RV. All changes was made to make it a direct bolt in a truck. The neutral safety switch was moved to the truck location on the column & the old hole was filled back in. The extra bend in the shift arm was taken out & is now straight like the truck & it has the correct truck upper & lower seals withe the metal firewall retainer. The column was stripped down & checked for worn or broken parts & replaced if needed. The column was painted semi-gloss black. The following parts are new, turn signal switch & wiring harness with correct horse shoe wiring connector, indicator pointer, upper & lower rubber seals, tilt & turn signal levers. Shift lever & cancel cam is used. This column will bolt right in with no modifications. I took pictures of a unrestored truck column sitting next to this column.
$ 395.00 Plus Shipping Fees / Payment - Personal Check or Postal Money Order Posted via Mobile Device |
12-10-2021, 06:48 PM | #2 |
More pictures
12-10-2021, 07:55 PM | #3 |
Junior Member
Re: Tilt steering column for Automatic trans.
I will take it. Tks Rod
12-10-2021, 08:06 PM | #4 |
12-11-2021, 06:41 PM | #5 |
01-09-2022, 08:51 PM | #6 |
01-10-2022, 12:54 AM | #7 |
Junior Member
If something falls through, I will take this! Thanks.
Wes
-1972 Chevrolet K10 LWB Pickup -1972 Chevrolet K20 Pickup -1972 Chevrolet K10 Suburban ... and counting |
01-10-2022, 11:44 AM | #8 |
01-20-2022, 06:26 PM | #9 |
01-22-2022, 11:01 AM | #10 | |
01-22-2022, 02:38 PM | #11 | |
01-22-2022, 03:12 PM | #12 |
Hey Don, I have a question. The auto trans shifter on my 69 C10 column has a lot of slop in it. For example, with the trans in Park, I can move the shift handle 1/2" up and down and the lever connected the the rod does not move. Same is true for any gear selected. And the slop is not between handle and shifter bowl.
Are there parts available to fix this problem? I'm getting ready to pull the column to take a look, but want to get your input.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Thread Tools | |
Display Modes | |
