Old 05-26-2022, 11:45 PM   #1
dmjlambert
dmjlambert's Avatar
Arrow Plug for 71-72 combination/proportioning valve
This looks like a bleeder or zerk to me in the right front brake port of the combination valve. Is that what it is? Is this sort of plug what was used from the factory, or does this happen to be what somebody used on this particular combination valve? Is it normal? it looks like a plastic plug in it.
I understand this is the port to right front brake for some vehicles, but this is plugged in the 71-72 C10 truck application
dmjlambert is offline   Reply With Quote
Old 05-27-2022, 11:15 AM   #2
Steeveedee
Steeveedee's Avatar
Re: Plug for 71-72 combination/proportioning valve
It's a bleeder screw. There is no seat for a flared brake line in that hole. Not sure what a '71-'72 combo valve looks like at this point. I ended up removing mine and putting a Wilwood valve in for the rear brakes on my truck.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-27-2022, 12:38 PM   #3
68 P.O.S.
I've seen a bleeder screw and a brake line attached to that port. Not sure what the different applications would be (a ton, I'm sure). Mine doesn't have that port drilled, just an indent. Are you trying to rebuild it? I'd like to know how to remove the metering valve.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 05-27-2022, 08:16 PM   #4
dmjlambert
dmjlambert's Avatar
I am going to send it to White Post Restorations and let them go through it and supposedly they are going to send it back to me in beautiful condition with lifetime warranty.
Thanks 68 P.O.S. and Steeveedee. I wanted to know if I was sending them something completely weird that they would not want to work on, but your answers gave me confidence there's nothing out of the ordinary with this valve so I expect they should be able to rebuild it.
combination valve, proportioning valve
Thread Tools
Display Modes
Copyright ©2000 - 2022, vBulletin Solutions Inc.
