07-17-2022, 07:46 AM | #1 |
Post Whore
How to treat hardware, nuts and bolts?
I am of the opinion that today's modern hardware is no way near the quality of the OEM stuff, (I think there's less "metal" and more "filler" but a metallurgist I am not, metal head yes!)hence I try to preserve the original nuts and bolts when ever I can, plus sometimes you gotta reuse something that is no longer available in the aftermarket world
recently I finally got into media blasting, and oh my goodness what a game changer (yes it took me about a month to dial it all in, little things, like oh being able to see inside my media blasting cabinet, lol) anyway so now I have thse "naked" bolts, now I also do my own powder coating, but that is very time consuming for nuts and bolts, and even if I was going to powder coat them I don't powder coat the threads I also tried Eastwood cold plating kit, I don't recall if it was zinc plating and bluing but that sucked either way I also tried the heat them up with a torch and dip them in old used engine oil, but I hear that changes their strength properties so I only do that for ornamental hardware (like the grille, etc) and not structural (actually works great and the nuts and bolts stay black and don't rust) so I am open to suggestions |
07-17-2022, 11:29 AM | #2 |
Re: How to treat hardware, nuts and bolts?
This is something I want to try
There are lots of video's out there to do (Electro-plating) home plating. This is the simplest one I found. Beside his annoying (Second person) voice
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
07-17-2022, 11:40 AM | #3 |
Caswell black oxide, restores original finish
07-17-2022, 01:38 PM | #4 |
Post Whore
Theres a guy near here that does the electro plating on all his hardware..it looks good when hes done
07-21-2022, 02:04 AM | #5 |
Post Whore
thank you all for your feedback, here is an excellent video on using motor oil to blue them bolts, he does a really good job of explaining the color changes as you heat up the metal
Delboy's Garage, Simple Skills, "Rust Proofing Bolts" |
07-21-2022, 02:10 AM | #6 |
Post Whore
nothing to it but to do it
07-22-2022, 09:48 AM | #7 |
Post Whore
07-28-2022, 09:44 AM | #8 |
Post Whore
oh this is the garbage I used from Clint Eastwood back in 2015
07-28-2022, 09:56 PM | #9 |
Post Whore
Nice video.... I'm somewhat suprised, knowing how scientific you are, that you wernt using a temperature gun on the bolts when you heat them... I know it dont take much to do it..weve treated alot of metal in oil at the farm over the yrs..
07-29-2022, 09:26 AM | #10 |
I have used the Caswell plating black oxide solution with good results (link below). To keep them looking good you must use a sealer on them after the black oxide treatment. I am going to watch the video and see the results for comparison.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-31-2022, 06:14 PM | #11 |
Post Whore
thanks, I clicked on your link and saw someone recommended the Eastwood product I used there, so I clicked that link and the result below speaks volumes, ha ha
07-31-2022, 07:33 PM | #12 |
What I do with all my bolts, is soak them in EvapRust. Rinse and drop them in oil. Good to go.
The brackets were sandblasted & repainted.m
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
08-01-2022, 01:41 AM | #13 |
I’ve got a glass bead blaster, but what I do with my small bolts etc, is put them in an old vibratory tumbler that is left over from where I upgraded my reloading tumbler. My arthritis sometimes makes it difficult to hold small stuff to blast. Put it in the tumbler, turn it on, and walk away.
I do have a variety of tumbling media, so may change sometimes to something more “aggressive” (ranges from corn cobb media to stainless steel pins) |
08-03-2022, 09:40 AM | #14 |
08-03-2022, 10:04 AM | #15 |
No heat. Most of the time it’s overnight. The ones that are really bad, I take them to the sink and use a small wire brush on them, and then drop them back in for a few days. They can stay in for days on end.
I do all my seat tracks also in EvapoRust also. I have a plastic rectangle planter that I filled with EvapoRust. Then I submerse the entire set of tracks down in the fluid. The next day I take them out and rinse, and immediately blow them dry with the air compressor nozzle. When they are good and dry, I repaint them. And then lube the bearings & rollers.
08-03-2022, 10:37 AM | #16 | |
Post Whore
08-03-2022, 10:13 PM | #17 |
Greg,
You might try the local home store for concrete etching solution. I think the name around here is Etch-n-Prep or Etch and Prep or something in the paint or concrete toys sections. I wouldn't leave parts in it longer than necessary depending on how diluted it is. It's phosphoric acid and I suspect it's the base for numerous rust removal stuff like Evaporust. Note that you need to dilute it and don't get it on concrete--it dissolves it. It also removes galvanized plating in case anyone cares. |
08-04-2022, 10:36 AM | #18 | |
Post Whore
as far as diluting it, well maybe 10 years ago yes, but I know for a fact they have changed their formula since then here in California, you can almost drink this stuff these days it's that weak |
Thread Tools | |
Display Modes | |
