06-17-2023, 06:17 PM | #1 |
Moderator
Bracket identification?
Picked up a couple boxes of parts and trying to ID them. Thanks for any input! Pic 1 I believe are K10 or K20 leaf spring hangers? Pic 2 is some kind of linkage? Pic 3 is a trac bar mount I believe but not sure what rear end it’s for? Pic 4 I know the triangle piece is for the rear of an AC compressor but the other bracket does not look familiar?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-21-2023, 01:22 AM | #2 |
Moderator
Re: Bracket identification?
Nobody?
06-21-2023, 01:35 AM | #3 |
First photo: the bottom brackets look like leaf spring frame mounts. Not sure about the top two brackets.
Second photo: appears to be throttle linkage. The large bracket at the top mounts to the interior of the fire wall and the small rod mounts between that bracket and the firewall. The large rod attaches to the carb and the small rod at the firewall. Third photo: I don't have a clue. Forth photo: Might be the rear bracket for the A/C compressor. The part with two bolt holes attach to the intake manifold. Or I'm completely wrong...
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
06-21-2023, 03:10 AM | #4 |
#1 leaf spring hanger 1970 and older, 71+72 are longer
#2 Automatic shift linkage
1972 C10 SWB 383 M22 1972 K20 454 1970 K5 1985 M1008 1986 M1008 2020 2500HD Duramax |
