Re: 454 vs 496 vs 502
I scored like a 20,000 mile engine out of a motorhome 800 bucks like new... ported with 30 hours of finess and pain cut my 3 angle valve seats on the peanut port heads.. the bottom end was already decked like ten, 0.020 head gasket yielding like8.1:1 instead of 7.9:1.. took a lunati 60202, had it custom ground on a 108 LSA to get just under 7.4 DCR , Gets 15in of vacuum with 16degrees initial and a q-jet at say 700 rpm .. cheap regular street sized headers... There is your 500+ ft lbs of torque... here is a similar with junk peanut heads( unported) same cam on the 112 LSA on 8.8:1 compression dynoed:
http://www.chevelles.com/forums/show...=309772&page=2 that 530 ft lbs like over 500 avrage with them garbage heads unported |
Posted via Mobile Device |
That sounds like a fun engine. I've been seriously considering building a 496. Would you be willing to share the basic info on the engine?
Here's some of the specs., I bugged a few folks on the site for their feedback durning the build, we have some good guys on this site! Crank Scat cast crank 9-454-4250-6135, 4.25 stroke Pistons Speed Pro w/H552CP , Moly Rings Rods Stk, reworked, Pins floated, ARP Wavelock bolts Heads 781 casting oval port 118cc, Milled .010 2.19 int./1.88 ext., .100 stainless valves Bowl blend and clean up runners Comp 10 degree locks & retainers Comp 930-16 dual valve springs Comp 1620-16 Ultra Pro Magnum roller rockers 1.7 Comp 3/8” Magnum push rods 7.75/8.75 Cam Comp Hydraulic roller part number 11-000-8 grind #cb3315/3356hr 112+5 Duration @ .050 230 int./242 ext. Lift w/ 1.7 rockers .578 int./.567 ext. LSA 112+5 degrees of advanced built in Fuel Pump- Holley Mechanical 110 gph Carb - Holley 870 Street Avenger Intake – Edelbrock Airgap |
Yes, thank you for sharing the info on your engine. :)
That helps those of us considering building a 496 in that we know a little more what it takes to achieve a given power goal. |
Yes Mr. Fab......I will keep you posted!!! lol Dub |
That's hard to beat. Posted via Mobile Device |
Naw.....don't mess with those little motors. Here is one of Mark's (vortecpro) little 650HP 496's in a 3.08 geared 71 vette.
http://www.youtube.com/watch?feature...&v=FYqBMqTgUwU |
