tcc brake switch ??
I am reworking a blue green harness and on the blue side pin number 33 is purple tcc brake switch wire can I just splice it in the hot wire to brake switch ? or splice it in the brake light hot side brake lights on ?
Re: tcc brake switch ??
No, you need to hook that to an ignition 12v, but that gets cut off when the brakes are applied. Do you have a 4 prong brake switch? You will need one if you don't. Here's a pic I stole from this site somewhere, but should help.
There will be a light blue wire on the TAC plug, pin 6 that goes to the cold side of the brake light switch, and you can hook that one up to your original brake light plug as it will need to see 12v with the brakes applied. |
ok my truck does not have that just 2 I got one on the way. I have been driving the truck for a few years without it never no problems other than the overdrive been having to back off the throttle for it to go in overdrive maybe this will solve that it looks just like that.
I bought this tcc switch and the destructions don't say anything about the light blue wire going to the tac module http://www.psiconversion.com/instruc...STRUCTIONS.pdf
That's because the instructions aren't for the whole engine harness. The GM manual shows it, I posted a pic of it in the cruise control thread, post #18. Light blue wire, pin #6 on the TAC plug. Needs power when the brakes are applied. http://67-72chevytrucks.com/vboard/s...d.php?t=511477
arnt you using a nv4500? or am I getting you mixed up with someone else?
the tcc switch disengauges the torque converter clutch (tcc) when you slow down... |
here it is explained.....https://www.freeasestudyguides.com/a...er-clutch.html
Really thank you, it is good information for me TCC . I have question that wire coming from TCC to pcm where exactly going to ?
Thx. |
