Old 04-20-2017, 03:59 PM   #1
63C20
63C20's Avatar
yes, another disk conversion question
i am wondering if there are specific spindles / parts off another vehicle i can slap on my 62 c20 (bolt on) without doing a whole cross member of frame chop?
63C20 is offline   Reply With Quote
Old 04-21-2017, 11:35 AM   #2
63C20
63C20's Avatar
Re: yes, another disk conversion question
anyone?
Old 04-22-2017, 03:08 AM   #3
andrewmp6
Old 04-22-2017, 02:28 PM   #4
63C20
63C20's Avatar
everytime i ask this people post that link, i have read every word of it and this isnt answered.
Old 04-22-2017, 10:18 PM   #5
68c10airstream
68c10airstream's Avatar
I guess i'll chime in with this, I don't know of a different vehicle line that will bolt in as i've read my share of various installs, but usually around a c10 platform. As a past dealer mechanic i would strongly consider going to the salvage yard and rob a complete crossmember from a newer c20, say mid 70's to late 80's, the later the better. Get everything, gearbox, lines, rag joint, fitting from the back side of the p/s pump (if it's the same basic style). The beauty of doing it this way is preventing a mismatch later down the road, and parts availability later will be reasonable.
With the gearbox change you will end up with a quicker ratio, and a variable ratio too. Frame mods to accommodate the box are needed i believe. The costs to do this should be bearable and pretty user friendly. Maybe even grab the stock sway bar while you are at it. You benefit from gobs of gm trucks in the salvage yard, gm engineering, one stop shopping. I agree it's a fair bit of work, but the first time you drive it you will smile and say it was worth it. Good luck.
68c10airstream is offline   Reply With Quote
Old 04-23-2017, 03:19 AM   #6
andrewmp6
Does your truck have torsion bars or coil springs in the front ?
