Old Guy
![]() Join Date: Nov 2002
"Drum to Disc" conversions 60-70
60-62 truck with: 63-70 Crossmember Installed ******************************** 60-62 Truck with: 71-72 Crossmember Installed ******************************** 60-62 Truck with: 73-87 Crossmember Installed ******************************** 60-62 Truck with: 71-72 Crossmember Not Yet Installed: ******************************** 60-62 Truck with: 73-87 Crossmember Not Yet Installed: ******************************** 63-66 truck with: 63-66 Crossmember Installed ******************************** 63-66 truck with: 71-72 Crossmember Installed ******************************** 63-66 truck with: 73-87 Crossmember Installed ******************************** 63-66 truck with: 71-72 Crossmember Not Yet Installed: ******************************** 63-66 truck with: 73-87 Crossmember Not Yet Installed: ******************************** 67-70 truck with: 67-70 Crossmember Installed ******************************** 67-70 truck with: 71-72 Crossmember Installed ******************************** 67-70 truck with: 73-87 Crossmember Installed ******************************** 67-70 truck with: 71-72 Crossmember Not Yet Installed: ******************************** 67-70 truck with: 73-87 Crossmember Not Yet Installed: ********************************************************************************* 60-72 truck with "Unknown" Crossmember Swap? * This is where it's hard to determine the correct parts needed. Here's the break down by year: Disc Brake Spindle: *60-70 (Aftermarket Conversion Spindles) *71-72 (oem or drop) *73-87 (oem or drop) C10 Grouped by Differences: *60-62 *63-70 *71-72 *73-87 (HD 1.25" wide rotors) *81-87 (LD 1.00" wide rotors) **Some 81-87 trucks also had the HD rotors** ** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version** C20 *71-87 Rotors: *71-72 (1.25" wide) *73-87 (HD 1.25" wide rotors) *81-87 (LD 1.00" wide rotors) **Some 81-87 trucks also had the HD rotors** ** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version** Calipers: *71-72 (1.25" wide) *73-87 (HD 1.25" wide rotors) *81-87 (LD 1.00" wide rotors) **Some 81-87 trucks also had the HD rotors** ** All Aftermarket 6-lug "Conversion Rotors Are the HD 1.25" wide version** Upper Ball Joint: Grouped by Differences: C10 *60-62 *63-70 *71-72 *73-87 C20 *71-87 Lower Ball Joint: Grouped by Differences: C10 *60-62 *63-70 *71-87 C20 *71-87 Control Arm Upper Cross Shafts: Grouped by Differences: C10 *60-62 *63-72 *73-87 C20 *63-87 Control Arm Lower Cross Shafts: Grouped by Differences: C10 *60-62 *63-72 *73-87 C20 *67-86 Inner Tie Rods: Grouped by Differences: C10 *60-62 *63-64 *65-70 *71-72 *73-87 C20 *60-64 (drivers side) *60-64 (pass. side) *65-70 *71-87 Outer Tie Rods: Grouped by Differences: C10 *60-64 *65-70 *71-72 *73-87 C20 *60-64 *65-70 *71-87 Tie Rod Adjusting Sleeves Grouped by Differences: C10 and C20 *60-64 *65-70 (5/8" thread) *71-87 (11/16" thread) Centerlink: Grouped by Differences: *60-62 *63-64 *65-70 *71-72 *73-87 Pitman Arm: Grouped by differences: C10 *60-66 Manual *60-66 P/S *67-72 Manual *67-87 P/S (Specify Year When Ordering) C20 manual: *60-66 *67-68 *69-70 *71-87 Power Steering: *69-70 *71-87 Idler Arm Grouped by differences: C10 *60-62 *63-66 *67-82 *83-87 C20 *60-66 *67-82 *83-87 Steering Box: Manual *60-62 *63-66 *67-82 *83-87 Power Steering
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 WTB: Radio Delete Plates and clips. Last edited by lolife99; 01-19-2013 at 10:40 AM. |
Thread Tools | |
Display Modes | |
