Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-21-2011, 09:06 PM   #1
darren509
Pin Removal on Bulkhead ?
So Im replacing all the bad and corroded wires I can find and Im down to the ones in the engine bay. The male connectors though I cant seem to remove. It looks like there is a small slot on both sides of the connector, Ive tried using a straight dental pick, a T shaped pin but cant seem to release it. It looks like the pin should have a tab on one side of it that you can push in and then pull it out. However, its just not working for me today. Any help?
darren509 is offline   Reply With Quote
Old 08-21-2011, 09:24 PM   #2
darren509
Re: Pin Removal on Bulkhead ?
Never mind. Did a search in here and found out how.........
Old 08-21-2011, 09:39 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Can you share what you found out?
Keith
Convert to disc brakes.
Old 08-21-2011, 10:11 PM   #4
darren509
I used needle nose pliers and squeezed the terminal gently and it pulled right out
Old 08-21-2011, 10:14 PM   #5
lolife99
lolife99's Avatar
Thanks.
Keith
